Newbie on VAG Com
onlinesys
Newbie on VAG Com
Post by onlinesys » Tue Apr 07, 2009 4:08 am
Hi all,
Got the VAG Com 4.0.9 software and usb cable.
After I installed the software as per the instructions, I use a test on the Com3 port and the software mentioned the cable is found (but I didn't even connect the usb cable to the usb port of my notebook)
I then saved the setting and just run any other 5 applications of the software but the program just "freezed" and quit!!
I tried to connect the cable first (it was detected by windows) but the outcome was the same. I even re-installed the software but no luck.
Any clue? (I am using Windows Vista) :oops:
PetrolDave
RE: Newbie on VAG Com
Post by PetrolDave » Tue Apr 07, 2009 1:17 pm
IIRC 409 isn't supported on Vista.
reevesroadster
Post by reevesroadster » Tue Apr 07, 2009 6:26 pm
I dont think much is supported on Vista..........
Everyone is unique, just like you and me.
PetrolDave
Post by PetrolDave » Tue Apr 07, 2009 7:05 pm
VCDS (VAG-COM) 7xx and 8xx work fine on Vista...
onlinesys - since you have VAG-COM 409 I'm guessing you don't have a genuine Ross-Tech lead? The symptoms you describe are typical of a third-party lead...
This is why I always recommend a genuine Ross-Tech lead - you pay more up front, but you pay once!
onlinesys
Re: RE: Newbie on VAG Com
Post by onlinesys » Wed Apr 08, 2009 12:23 am
PetrolDave wrote:VCDS (VAG-COM) 7xx and 8xx work fine on Vista...
You are correct! I am using a third party cable given from someone :oops: Did work once or twice but not anymore!!
Will check out at ross-tech.com now.
PetrolDave
Post by PetrolDave » Wed Apr 08, 2009 8:08 am
onlinesys wrote:Did work once or twice but not anymore!!
That's also typical of a third-party lead!!!
Return to “DTC / VCDS”
Users browsing this forum: No registered users and 31 guests
