steering squeek
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
Nodds
steering squeek
Post by Nodds » Thu Mar 26, 2009 8:27 am
When turning he steering wheel there is a squeeking/ rumble noise that sounds like its coming from behind the dash
Any ideas whats causing this
Nodds
bobbler
RE: steering squeek
Post by bobbler » Sat Mar 28, 2009 11:53 pm
Full lock? I found ours is the power steering fluid had run low - which was actually caused by a leak in the pipes by the cooler bit.
. S4 Nogaro Blue Avant . ECS IV . RS4 handling bits . 18" Ultraleggera . AWE Boost Gauge . MRC Custom Map . 315 BHP . 482 Nm .
Nodds
Post by Nodds » Wed Apr 08, 2009 12:43 pm
No not on full lock, just when you turn the wheel slightly, usually on start up, just as you are pulling away, not always there either which is a pain
Trig
Post by Trig » Sat Apr 11, 2009 5:56 pm
Nodds wrote:No not on full lock, just when you turn the wheel slightly, usually on start up, just as you are pulling away, not always there either which is a pain
Squirt a load of silicone spray down the column, could be catching the cover or the top bush could be dry.
