first time using vagcom
rtd
Post by rtd » Thu Mar 19, 2009 7:16 pm
ok guys i did a normal scan (if thats what you call it) and this is what came up. does this mean these are the only faults vagcom found or are there other scans i can do to look for faults elsewhere? not that i want to find any other faults :)
Thursday,19,March,2009,17:41:33:14480
VCDS Version: Release 805.3
Data version: 20090213
Chassis Type: 8D - Audi A4 B5
Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
VIN: WUAZZZ8DZ1N904257
Address 01: Engine Labels: 078-907-551-AZA.lbl
Part No: 8D0 907 551 K
Component: 2.7l V6/5VT G 0001
Coding: 10711
Shop #: WSC 63351
WUAZZZ8DZ1N904257 AUZ7Z0Y1767343
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 8D0-907-389.lbl
Part No: 8D0 907 389 E
Component: ABS/ESP allrad D56
Coding: 04395
Shop #: WSC 00720
Address 08: Auto HVAC Labels: Redir Fail!
Part No: 8D0 820 043 P
Component: A4 KLIMAAUTOMAT D58
Coding: 00061
Shop #: WSC 63351
1 Fault Found:
00779 - Outside Air Temp Sensor (G17)
30-00 - Open or Short to Plus
Address 15: Airbags Labels: 8D0-959-655-AI8.lbl
Part No: 8D0 959 655 F
Component: Airbag Front+Kopf 2001
Coding: 01306
Shop #: WSC 02314
Address 17: Instruments Labels: 8D0-920-xxx-17.lbl
Part No: 8D0 920 981
Component: B5-KOMBIINSTR. VDO D13
Coding: 00464
Shop #: WSC 00720
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8D0 862 257 E
Component: CV-Pump, Alarm, RC D17
Coding: 15210
Shop #: WSC 63351
1 Fault Found:
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
Part No: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00102
Shop #: WSC 63351
Address 55: Xenon Range Labels: 4B0-907-357-AUT.lbl
Part No: 4B0 907 357
Component: LEUCHTWEITEREGLER D004
Coding: 00012
Shop #: WSC 63351
End ---------------------------------------------------------------------
Volvo XC90
C7 - RS6
C6 - RS6
B5 - RS4
tartan_rob
RE: first time using vagcom
Post by tartan_rob » Thu Mar 19, 2009 8:03 pm
It sure does...
2017 Kawasaki Z1000
2014 RS6
2014 S1
PetrolDave
Post by PetrolDave » Thu Mar 19, 2009 8:17 pm
So you may have a faulty G17 sensor and at some time you triggered the alarm...
Try clearing those fault codes and see if they come back, that will tell you if the G17 really is faulty (or maybe the wiring to it...).
rtd
Post by rtd » Thu Mar 19, 2009 8:20 pm
petroldave - the g17 im aware of been showing for a while just not got round to getting it sorted.
Volvo XC90
C7 - RS6
C6 - RS6
B5 - RS4
jimbo1234567
Post by jimbo1234567 » Thu Mar 19, 2009 11:35 pm
looks good to me :thumbs:
rtd
Post by rtd » Fri Mar 20, 2009 7:06 am
thanks jimbo - yep i'm fairly happy with that. when i bought the car it was only showing one fault code so its keeping up the good work. the less fault codes the better! :)
Volvo XC90
C7 - RS6
C6 - RS6
B5 - RS4
Return to “DTC / VCDS”
Users browsing this forum: Google Adsense [Bot] and 29 guests
