Cost of running a RS6+ Discuss
deanobeano
Post by deanobeano » Thu Mar 19, 2009 5:45 pm
I have recently put a deposit down on a 54 plate RS6+ from a Main Dealer and will be picking her up next week.
I got a print out of the cars history, One owner, bought from the same dealer and serviced there until they bought it back as part ex on a C6 RS6.
I thought you may want to know the costs incurred during its first 4 years of life.
Below is a summary of the works with costs performed on the motor. (W) indicates warranty work, but they have listed the cost for this. Not sure if the values are ex vat. Oh, the numbers in brackets is the mileage
ps - why so many wiperblades!
pps - apologies if this is anyones previous car - mods feel free to remove if inappropriate.
Here goes:
By dealer as used car sales prep (55721)
110 point check
number plates
replaced front and rear wiper blades
carried out screen repair
replaced front pads
replaced damper seal (what's this?)
variable servicing 1
Mot
total 1114.19
03.7.08 (55684) (W) renew NSF and OSF shocker and valve £1620.04
08.11.07 (47045) Annual service
brake fluid change
replace wiper blades all round
replace ns brake caliper bleed nipple
replaced front pads £598.12
06.11.07 (47045) replace both front shocks accumulators pipe work
and nsf top suspension arm (w) £1967.18
07.08.07 (43765) (w) renew nsf and osf outer CV boot and joint £232.23
27.04.07 (40818)supplied and fit two new road wheels and tyres £1931.25
01.02.07 (37941) 40K service replace cambelt and tensioner
replaced front pads and discs replace rear pads replace rear
wiper blade. brake fluid change £2619.80
08.12.06 (35518) replace front bumper £1027.74
01.12.06 (35518) (W) renew nsf/osr accumulator renew ns mirror glass
renew centre armrest £1043.95
25.08.06 (31076) (W) renew nsf / dsf / dsr shock absorbers £1675.45
19.05.06 (28176) annual service replaced wiper blades all round £322.43
21.04.06 (26868) (W) replace Nav uni reconnect washer pipe £990.19
17.03.06 (25501) replace front brake pads and discs £907.85
27.10.05 (18626) 20k service. replace wiper blades £486.20
22.08.05 (15668) (W) replace air con drain pipe £74.14
11.07.05 (13947) (W) replace foglight £85.18
11.07.05 (13947) replace front pads and discs £366.47
06.05.05 (10661) (W) replace horn £268.30
24.03.05 (8832) (W) carried out geometry check £69.96
24.03.05 (8832) annual service. removed foglight and resealed £200.14
25.08.04 (10) fit road angel tracker monitor and phone adaptor £814.79
11.08.04 (0) PDI number plates and fuel £198.48
Thats it, quite a list, or is this normal for a RS6?
Please discuss!!
:shock:
deanobeano
RE: Cost of running a RS6+ Discuss
Post by deanobeano » Thu Mar 19, 2009 5:50 pm
Thats £18,614.08, possibly plus vat and not including tyres!
Should I be afraid, very afraid? or think of all that money (someone else's) that has been lavished on my soon to be car?
08 Prius (saving money)
RS6+ (spending money)
Daveperc
Post by Daveperc » Thu Mar 19, 2009 5:52 pm
Yep that looks about right - though the previous owner seems to have done some damage at the front at some stage.
At least four goes at the DRC, and three of them (if the reports are correct) done WRONG!! You have to replace the shocks on the diagonal, and the accumulator at the same time - every instance above breaches this - so expect more failures to come.
Good luck!
Rupert
Post by Rupert » Thu Mar 19, 2009 5:56 pm
The total is only 18.6k, unless I have calculated it wrongly.
I'll just put some more fertiliser on the money trees in my garden. :D
£6305 for suspension, no wonder warranty companies don't like it.
There are other bits which must have been damaged, such as fog light, front bumper etc, so those are not normal.
Brakes discs and pads are an easy-ish DIY job. Servicing at a specialist will be much less than the dealer.
Looks like this car could be described as "maintained regardless of cost" ;)
Rupert
Post by Rupert » Thu Mar 19, 2009 5:58 pm
Wiper blades are £45, every year or so. Maybe the dealer was adding half-hour labour to fit them?
deanobeano
Post by deanobeano » Thu Mar 19, 2009 6:01 pm
DRC, I was more worried about the number of wiperblades - Just joking!
Seriously, it will come with 1 years warranty and they are giving me the option to extend it to two years for £975, which, based on the costs incurred above, I will go for.
deanobeano
Re: RE: Cost of running a RS6+ Discuss
Post by deanobeano » Thu Mar 19, 2009 6:06 pm
Rupert wrote:
There are other bits which must have been damaged, such as fog light, front bumper etc, ;)
Thats why you cannot change the front pads and discs enough!
GardinerG
RE: Re: RE: Cost of running a RS6+ Discuss
Post by GardinerG » Thu Mar 19, 2009 6:37 pm
I've always thought the wheels were too expensive from Audi considering MTM Bimotos are over £200 cheaper a wheel.
1. replace front pads and discs £366.47
2. replace front brake pads and discs £907.85
Eh? Discs are about £450 for the drilled ones, pads are £200, takes an hour to do.
40k service typically way overpriced compared to indies like Unit 20 or MRC.
I suppose he was glad that the (Audi) warranty covered all the parts replaced.
ollys
Post by ollys » Thu Mar 19, 2009 6:40 pm
looks like it might need new front discs, as although pads were done recently discs were at last done 38k and were historically changed on the car before that every 13k. Someone here will tell you if that's how long they should last, but be prepare to negotiate for a new set.
ollys
Post by ollys » Thu Mar 19, 2009 6:41 pm
doesn't look like rear discs have ever been done too!
the_boy
Post by the_boy » Thu Mar 19, 2009 7:04 pm
This car didn't come from Worcester did it?
I only ask as I enquired about this car at the weekend...
deanobeano
Post by deanobeano » Thu Mar 19, 2009 7:46 pm
Worcester it is.
The dealer said that he had a few recent enquires, as the price had been reduced.
Were you interested enough to consider buying?
If so, sorry I beat you to it.
deanobeano
Re: RE: Re: RE: Cost of running a RS6+ Discuss
Post by deanobeano » Thu Mar 19, 2009 7:51 pm
ollys wrote:looks like it might need new front discs, as although pads were done recently discs were at last done 38k and were historically changed on the car before that every 13k. Someone here will tell you if that's how long they should last, but be prepare to negotiate for a new set.
Anyone know what the minimum disc thickness should be?
Also, should disc thickness be picked up on the Audi 100 and something used car checklist?
posterboyj
RE: Re: RE: Re: RE: Cost of running a RS6+ Discuss
Post by posterboyj » Thu Mar 19, 2009 7:59 pm
33 mm (1.30 in)
Cornishmoocher wrote:Buying an RS6 and then worrying about the fuel consumption is a bit like buying a boat and worrying about getting it wet.
Hartge
Post by Hartge » Thu Mar 19, 2009 8:20 pm
Ah, I know the car.
Ive look around it a few times while ive been hanging around Audi Lister getting my 6+ serviced (30/09/08) and gearbox replaced (08/01/09)
Its been there since the end of September, originally on the forecourt for around 32 or 34k if I can remember correctly - very tidy and clean example.
Got yourself a good car there.
BTW: I'm sorry to say the running costs are horrendous if you do average milage per year (consumables like brakes, tyres & fuel) and warranty is essential unless you have very deep pockets.
Users browsing this forum: No registered users and 1566 guests
