H&R and Hotchkis Sway-bars settings
onlinesys
Post by onlinesys » Mon Mar 09, 2009 2:03 pm
Hi Gents,
Finally I could get rid of the bloody DRC and install the best combo -- H&R coilovers and Hotchkis Sway-bars. :wink:
Did a search but no info on the recommended settings on the H&R and Hotchkis Sway-bars within the RS6 C5 forum. :cry:
Can someone recommend a setting for typical UK B-road? We don't have good person like Grizz over here? :cry:
Cheers,
ChrisS2
RE: H&R and Hotchkis Sway-bars settings
Post by ChrisS2 » Mon Mar 09, 2009 2:06 pm
The front hotchkis bars are not adjustable, i'd set the rear to hard on the RS6.
skyegtb
Re: RE: H&R and Hotchkis Sway-bars settings
Post by skyegtb » Mon Mar 09, 2009 2:33 pm
ChrisS2 wrote:The front hotchkis bars are not adjustable, i'd set the rear to hard on the RS6.
I 2nd that, definitely set the rear to the harder setting.
onlinesys
Post by onlinesys » Mon Mar 09, 2009 3:23 pm
Thanks for your info. How about the front setting?
Also, is there any recommended ride height settings (front and rear) if the rear setting is the hardest? Apologize if I am asking silly question.
:oops:
Gavc500
RE: Re: RE: H&R and Hotchkis Sway-bars settings
Post by Gavc500 » Mon Mar 09, 2009 11:07 pm
Hotchkis fronts are one setting only, rears have two settings, from memory the settings are about 50% and 65% stiffer than OEM, so use the stiffest setting.
Ebony Black Avant with Black Optics, Silver Leather and Piano Black/ Full Milltek - 100 CPSI cats and non-resonated! TVR for the summer..... and SL55 AMG just for the pose!!
onlinesys
Re: RE: Re: RE: H&R and Hotchkis Sway-bars settings
Post by onlinesys » Tue Mar 10, 2009 3:16 am
Gavc450 wrote:Hotchkis fronts are one setting only, rears have two settings, from memory the settings are about 50% and 65% stiffer than OEM, so use the stiffest setting.
Thanks GAVC450. How about the H&R? Is it just a matter of personal preference for the ride height and/or the condition of the road or something more complicated??
philroach
RE: Re: RE: Re: RE: H&R and Hotchkis Sway-bars settings
Post by philroach » Tue Mar 10, 2009 9:07 am
just had mine done by Grizz . He recommended the softer setting for the arb ,height is a personal preference , doesnt effect ride , unless it is so low you lose your sump on speed bumps , he lowered mine so you cant see the top of the tyre in the rear arch , very nice
Phil
MartynC
Post by MartynC » Tue Mar 10, 2009 9:44 am
Griz set mine the same....softer setting and kept the optional 10mm lowered setting that I opted for when I bought my Plus.
Sure has improved the car.
MartynC 8)
onlinesys
Re: RE: Re: RE: Re: RE: H&R and Hotchkis Sway-bars setti
Post by onlinesys » Tue Mar 10, 2009 9:47 am
philroach wrote:just had mine done by Grizz . He recommended the softer setting for the arb ,height is a personal preference , doesnt effect ride , unless it is so low you lose your sump on speed bumps , he lowered mine so you cant see the top of the tyre in the rear arch , very nice
Phil
Thanks Phil for your info. I will try to follow your setting of "can't see the top of the tyre in the rear arch"
Cheers :wink:
philroach
Post by philroach » Tue Mar 10, 2009 12:21 pm
MartynC wrote:Griz set mine the same....softer setting and kept the optional 10mm lowered setting that I opted for when I bought my Plus.
MartynC 8)
I nearly wet myself , swooping down on to the M56 , and not having any bodyroll , damn it has stiffened things up !!
Cornishmoocher
Post by Cornishmoocher » Tue Mar 10, 2009 12:24 pm
Told ya.........
It's all Bollox.
GardinerG
Post by GardinerG » Tue Mar 10, 2009 12:34 pm
^^^ like he said. I can't wait till the track day at Bedford now... mmmm
Gavc500
Post by Gavc500 » Tue Mar 10, 2009 8:40 pm
OK, well I'm surprised that you buy stronger ARB's and use the lesser rear setting which admittedly is 50% stiffer than OEM, however the stiffer setting gives a little more at 65%.
So if you use the slightly softer setting on the rear ARB, it allows more flexing at the rear and the front wheels do not have to do as much work to get round the corner....., but if you use the stiffer setting, it can cause the front to work harder and understeer on cornering..... unless you use the ackerman setup principle of slightly toeing out the front.... then you have a go kart effect on cornering, goes round on rails!!
Anyway all personal preferences, just have fun with the setup. :thumbs:
BigMo
Post by BigMo » Tue Mar 10, 2009 10:20 pm
I think a 10mm drop will suffice. Any lower and you may find problems with some of the Wilson carpark ramps!!!
RS6 (MRC'd with econodrive) is not just for Xmas
Toyota Aygo Platinum for minimising carbon footprint.
onlinesys
Post by onlinesys » Wed Mar 11, 2009 1:15 am
Gavc450 wrote:OK, well I'm surprised that you buy stronger ARB's and use the lesser rear setting which admittedly is 50% stiffer than OEM, however the stiffer setting gives a little more at 65%.
Hmmmmmmm!! Seems very sensible setting. Is it easy to change from stiffer to softer setting on the rear ARB so that I could try both or I would have to pay a lot on the labour fee?
Users browsing this forum: No registered users and 128 guests
