hi guys
the S4 has picked up a misfire - it seems to be missing a beat on the n/s cyclinder bank at very light loads just off tickover. you can hear it popping and farting somewhere on that side.
everything seems fine under power.
also worse when cold. i took it to the local specialist & he says there's no fault code logged (i don't have vagcom)
he's going to try it again when cold
it doesn't seem anywhere near bad enough to be a coilpack - i had one go on my S3 and the engine ran like an absolute bag of nails..!!
any of you guys got any ideas ??
misfire - any ideas ?
RE: misfire - any ideas ?
I've had that - took a while to sort out but replacing the plugs, PCV valve (which was completely blocked) and front lambda sensors fixed it. It was really difficult to diagnose because it wasn't logging misfires or faults - but it definitely felt like a misfire.
Also might be worth changing the fuel filter if it's never been done.
RS6 Avant (C5), Daytona grey
Gone but not forgotten: S4 Avant (B5)
Expensive trial and error mate! Give me a shout if you need to run VAG COM over it and some real time logs. Can also try some bits off mine within reason.batty wrote:hi dazzer
2 garages failed to solve
I've got a new coil pack on order, so will try by process of elimination.
Which garages did you try out of interest?
thanks for the offer, mate
i won't name the garages, as it wasn't really their fault.
the first put their scanner tool on it and couldn't see a fault, but did notice a throttle hesitation when driving. they offered to try several sensors one-at-a-time but rightly warned me it could be expensive as the sensors can't be returned if found not to cure the fault.
the misfire is only at cold, although both garages kept the car overnight.
i think they didn't really see the slight misfire at cold as a problem - but you know when your own car's not right..!!
but the "hesitation" issues has put the seed of thought in my mind and it won't go away....the car has never had "sharp" feel on the throttle - goes perfectly at wide-open-throttle - but response is a bit woolly.
hmmm....
hmmm....
c5 RS6 plus in silver
Fair enough about the garages. Let me know if you want some VAG COM help.batty wrote:thanks for the offer, mate
hmmm....
jimbo1234567
- 5th Gear
it could be the coolant temp sensor thats goosed . if so it will tell your ecu that the engine is warm when its cold and not give enough fuel(choke) hence the misfire/hesitation when cold. thats a simple /cheap fix
665 bhp + 586 lbft...
