Immobilise...
2.7 V6 30v biturbo - 380 bhp
rickoshea
Immobilise...
Post by rickoshea » Sat Feb 14, 2009 7:31 pm
Have to leave the car in an Airport Car Park for a week ( a conventional car park where I park the car and take the keys with me ).
What do others do - is there something worth 'disconnecting' ( that is not too obvious ) to add to the difficulty in starting the motor should a tea leaf take a shine to it ?
I'll be taking my Disklok as well....
Feel free to PM me if you prefer.
TIA
Rick.
neckarsulm
RE: Immobilise...
Post by neckarsulm » Sat Feb 14, 2009 7:49 pm
Disklok is a very good deterent and should be enough to put people off.
You could pop fuse box cover off and remove fuel pump fuse or ECU fuse or even better but a duff fuse in their place, call me devious.. :D
bustermb
RE: Immobilise...
Post by bustermb » Sun Feb 15, 2009 1:12 am
i would do the same even take wheel off and put on a stand more work for them :nogarors4:
tdiquattro
RE: Immobilise...
Post by tdiquattro » Sun Feb 15, 2009 10:22 am
i usually pull the connector off the throttle body, just enough so it is disconnected but still slid on to the socket, you have to pop off the front engine cover but it is only 2 screws, i dont think anyone would find it loose as it looks ok, plus you cant se it without removing the cover.
Nige'
2000 silver S4 Saloon
Doug_S2
Trader (Expired)
RE: Immobilise...
Post by Doug_S2 » Sun Feb 15, 2009 2:23 pm
We fit a hidden switch that disables the k line to the ecu so an immobilser defeat box used by criminals does not work and it disables fuel pump(and or other things) You want a visual deterrant first. When the deimmo box they use does not work they usually don't spend the time trying to work out why.
http://www.MRCtuning.com
Blue_Thunder
RE: Immobilise...
Post by Blue_Thunder » Sun Feb 15, 2009 2:26 pm
I've removed my fuel pump fuse in the past.
neckarsulm
RE: Immobilise...
Post by neckarsulm » Sun Feb 15, 2009 7:27 pm
What's a deimmo box? Sounds worrying..
Doug_S2
Trader (Expired)
RE: Immobilise...
Post by Doug_S2 » Sun Feb 15, 2009 7:30 pm
how do you think thieves steal new cars with ecu immobilisers?
Just plug in a box and then they can use a screwdriver to start the car.
neckarsulm
RE: Immobilise...
Post by neckarsulm » Sun Feb 15, 2009 7:39 pm
I always thought it was with the keys hence all the car jacking/burglaries etc.
Doesn't surprise me though, better dust off my Disklok..
mbelle
RE: Immobilise...
Post by mbelle » Sun Feb 15, 2009 11:12 pm
Get a lift
Marcus
Current: A C6 Audi
Previous: A B5 Audi
rikrose
RE: Immobilise...
Post by rikrose » Mon Feb 16, 2009 12:40 pm
That's the best suggestion.
Goodwood green RS4, previously owned by jeffw
Blue_Thunder
Re: RE: Immobilise...
Post by Blue_Thunder » Mon Feb 16, 2009 1:57 pm
mbelle wrote:Get a lift
Then your car is sitting outside your empty house for the duration of your holiday, putting both the car and the contents of your home at risk.
Jules
Post by Jules » Mon Feb 16, 2009 2:48 pm
I bet you'd have plenty of friends that would look after it for you :lol:
Post by HYFR » Mon Feb 16, 2009 10:32 pm
surely the car park is secure? barriers, camera's etc ? thats what your paying for isnt it?
rickoshea
Post by rickoshea » Tue Feb 17, 2009 12:38 am
Thanks for the suggestions guys - some good options there. I'll probably go for a combination of options. I'm picking my friends up for the holiday, so that's not an option. Then again, would I trust them.. :?
Too late now to investigate Doug's hidden switch option, however will add that to the list for the next MRC visit !
