Heeellllppp!!!! Turbos on their way out?
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
Mac_Xpert
Post by Mac_Xpert » Fri Feb 13, 2009 7:07 pm
Just took my dump valves off to swap them for 710n's. One of them had a little oil in it, which seems to have some silvery sheen in it.
Now my worry is that this is a sign my turbo on the passenger side is dead, or dying. Anyone had the same experiance? Should i change immediately?
Can i fit K04's and just keep everything else standard? Or what other hardware do HAVE to have to fit them?
Matt
dazzer
Re: Heeellllppp!!!! Turbos on their way out?
Post by dazzer » Fri Feb 13, 2009 7:23 pm
Mac_Xpert wrote:Just took my dump valves off to swap them for 710n's. One of them had a little oil in it, which seems to have some silvery sheen in it.
Matt
Nah don't think it's a sign that the snails are on the way out.
yorkie
RE: Re: Heeellllppp!!!! Turbos on their way out?
Post by yorkie » Fri Feb 13, 2009 7:53 pm
I would be worried if there wasn't a little bit of oil in the passenger side DV and associated pipes.
It comes from the breather and if it wasn't there you could have a blocked one.
Loads of oil would be a worry but you would be making smoke.
Mac_Xpert
Post by Mac_Xpert » Fri Feb 13, 2009 8:16 pm
If the oil was clear, then i wouldn't be worried, but if you rub it between two fingers the oil has metal in it. Its not just black oil.
I don't mean shards of metal, just silver powder disolved in the metal.
The oil is not from the Y-hose that connects to the inlet manifold, but from the post - turbo hose that connects into the throttle body boot.
If its not a bad sign, then obviously i'm happy!
yorkie
Post by yorkie » Fri Feb 13, 2009 9:56 pm
There will be a small amount of oil in all the hoses on the passengers side but not wishing to be alarmist or confessing to be an expert, Silver powder would suggest to me the lining of some bearing or other.
Having said that my Golf Rallye always had some Silvery powder in the oil residue in the boost pipes and never let me down in 8 years/132,000 miles and as far as I know is still going ok.
Mikey-S
Post by Mikey-S » Sat Feb 14, 2009 11:17 am
http://audisrs.com/ftopic4067-30.php
Read this thread.... this could explain the metal in your oil!! Get it checked out asap!
Doug_S2
Trader (Expired)
Post by Doug_S2 » Sun Feb 15, 2009 6:05 pm
Are you getting any oil out the back or high pitched noises from the turbos?
http://www.MRCtuning.com
Mac_Xpert
Post by Mac_Xpert » Sun Feb 15, 2009 7:18 pm
Not noticed any blue smoke or whining noise. All still sounds good to me.
Do you mean actual oil in the exhaust?
Main engine oil is still clear, so i don't suspect the cams...
Doug_S2
Trader (Expired)
Post by Doug_S2 » Sun Feb 15, 2009 7:22 pm
you can get silver paint flakes off the charge pipes or the y pipe around there. If yuou are worried about metal in the oil then change hte oil, and cut the old filter open and inspect that.
Users browsing this forum: Bing [Bot] and 74 guests
