Un-Official Audi tool No.7
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
Mac_Xpert
Post by Mac_Xpert » Wed Feb 11, 2009 2:10 pm
When you round off the head of the Audi S4 B5 Hub Bolt...
...Turn to Un-Official Audi tool No.7 :D
Anyone else had to use 'Un-Official' tools on their car?
imolas4uk
RE: Un-Official Audi tool No.7
Post by imolas4uk » Thu Feb 12, 2009 12:47 am
yeah i like that,a bit of heat from the welder helps aswell,hope that wheel bearing didnt get to hot,or is that why the hub bolt had to come off ?
1999 S4 bi turbo imola yellow,grey pearl wheels,now with KO4's.
2001 A6 avant 2.5 tdi,the work horse
Mac_Xpert
Post by Mac_Xpert » Thu Feb 12, 2009 11:47 am
Luckily Wheel bearing replacement was why it came off. Did lower bushes at the same time as i had to cut one of the camber bolts out.
stapo69
Post by stapo69 » Thu Feb 12, 2009 7:18 pm
I have a special chopped, grinded and adapted long 17mm spanner for getting the passenger side egt sensor tight as space is a bit limited! As well as that anther ut down spanner to get to the bolts at the top of my main cts. Also I took my passenger rear wheel ff the other day and found a socket still wedged on the hub nut! Dunno how long hat'd been there!
Doug_S2
Trader (Expired)
Post by Doug_S2 » Sun Feb 15, 2009 2:18 pm
i have a toolbox full of cut,bent and right angle lumps of metal for special tools!
Well saved!
http://www.MRCtuning.com
Bluebrakes
Post by Bluebrakes » Mon Feb 16, 2009 12:05 am
Not on my s4 but I have had to make all sorts of special tools for my bikes.
A tool to hold clutch basket whilst you undo the bolts, which is simply a long handle and two bolts welded on.
A tool to remove the stupid honda locking nut on clutch baskets. I can't think why they would use this type of nut other than to prevent the home mechanic doing it themselves.
Why do they call it rush hour when nothing moves!?!
Standard S4, but not for long.
rikrose
Post by rikrose » Mon Feb 16, 2009 12:35 pm
To get to one of the nuts in a SR18DET engine for changing a turbo gasket, the recommended method is to remove the engine. The real method is to take a spanner, heat it up where the neck meets the tool part, and bend it fifteen degrees. Every 200SX owner in the countr that works on their own car has one of these tools in their toolbox.
Goodwood green RS4, previously owned by jeffw
grizz
Post by grizz » Wed Feb 18, 2009 12:31 am
I've got a nice big 1" air gun for removing the drive shaft bolts .....
Unit 20
0151 3366888
tartan_rob
Post by tartan_rob » Wed Feb 18, 2009 1:53 am
Hammer, chisel or angle grinder. Doug will vouch.
2017 Kawasaki Z1000
2014 RS6
2014 S1
KayGee
Post by KayGee » Mon Feb 23, 2009 9:41 pm
My dad once changed the clutch in a tractor with a hammer chisel and a pair of water pump pliers.
After that they re-instated the "replacement of any broken tools policy" they withdrew the week before.
:twisted:
