"Menu" wheel/switch
"Menu" wheel/switch
Posts coming thick and fast from me now!
The menu wheel/button by the wingmirror controls doesn't seem to be working on my car. What should it do? Toggle between nav, CD, radio and TV or something else? If its just to toggle between the display then I think I'll leave it be .. if its something more important however ...
Thanks,
Greg
Thanks,
Greg
RE: "Menu" wheel/switch
when you say doesnt work ? ? ? just make sure you press the actual button that has menu written on it, then use the toggle wheel. . . . dont press the toggle wheel itself to bring up the menu
if its still broke then fyi, it tells you when your next due a service, but not sure how correct this is as mine is wrong (assuming 10k fixed servicing). . . it lets you set a speed warning (handly set at license losing 100mph), it lets you turn on the tyre pressure monitors and set the pressures, think it also lets you set date and time etc ?
anything iv missed ?
I bet it's working... The trick is that you press Menu where it actually says "Menu". It's more than just a label.
- chriswebb9
Greg's Button
Hi Greg, hopefully it's not me suffering from too much wine, but I didn't read a reply to your query on the menu button, which covered the actual use of the MENU button and the DIS screen it controls??
If you've been fiddling and found out what you can do by now, then move on, but if you haven't, then you may find the breif outline useful.
When you press 'menu' (lower centre console by mirror dial for those new to this blog) your RED Driver Info Screen changes (this is the red LED panel between the speedo and tacho on the dash). What you'll notice is, that the display has now changed from say MPG, or mini sat assist mode, to what now becomes some set-up menus for changing things. Such as - what the fuel computer shows you, adjusting/setting the speed warning indicator beeper, to setting the clock, or storing the tyre pressure settings.
It's a useful little knob (unlike me), but generally once you've been in there and set it, then, there's little need to regularly go back into it - I'm still talking about the menu button by the way!
Sorry if i've bored anyone with this.
Regards,
CW
Regards,
CW
RE: Greg
When I was test driving the car, I too pressed the button expecting to see something happen on the big display controlling the sat nav or something. Just the DIS and as above nothing to get too excited about!
Steve
Steve
2011 Audi RS3 Daytona Grey | 2003 Audi RS6 Avant Ebony Black
