Wanted: S4 (b5) Headlight.
StuH
Post by StuH » Tue Jan 27, 2009 4:35 pm
I need a drivers side headlight for my pre-facelift S4. I have heard previously that I may be able to get a new plastic case. The ballast, bulb , projectors ect are fine but it’s been missing the lower mounts pothole make the beam jump. A used headlight is my preference but any advice is appreciated
Thanks in advance,
1999 Kingfisher blue S4 lightly fettled.
Blue_Thunder
RE: Wanted: S4 (b5) Headlight.
Post by Blue_Thunder » Tue Jan 27, 2009 8:34 pm
I've got a set of facelift lights for sale very soon. They are pattern parts (Depo) and are cosmetically identical to the Valeo units. The projectors aren't as good as the OEM pre-facelift xenon ones, but you could swap them out (although it looks like quite a bit of work).
Looking for £100 complete with HID kit, phillips sidelights and main beam bulbs (H7).
StuH
Post by StuH » Thu Jan 29, 2009 10:48 am
I quite like the idea of a set of facelift lights. I'm going to do some reading up on the work required to trim the wing flanges and possibly swap the projectors over.
After ive done a bit of web research and sussed what is involved i'll get back to you!
Blue_Thunder
Post by Blue_Thunder » Thu Jan 29, 2009 12:47 pm
Trimming the wing is really easy. I used Grizz's airsaw and did it in seconds. You could just as easily use a dremmel.
Getting the facelift plugs can be a PITA depending on how well stocked the breakers yards are. I'll try and dig out the guide to swapping the projectors.
StuH
Post by StuH » Thu Jan 29, 2009 12:48 pm
cheers
Blue_Thunder
Post by Blue_Thunder » Thu Jan 29, 2009 12:54 pm
http://www.a4mods.com/index.php?page=we ... /joey.html
Here's the link to how you go about opening up a headlight unit. Apparently once they're open, the projectors are a straight swap.
