Turbo whistle, limp mode, VAGCOM codes.... what am I in for?
2.7 V6 30v biturbo - 380 bhp
mylife98
Post by mylife98 » Sun Jan 25, 2009 11:56 pm
About two days ago, noticed a whistle whilst driving. Assuming it must be turbo related as the pitch increased with an open throttle. Starts as a low deep whistle about 2500rpm, rising rapidly in pitch as the rpm increases (whilst holding the throttle open). Ceases immediately on closing the throttle.
Had a good look and listen this morning: the whistle appears to come from the near side deep back of the engine.
On the motorway drive back to London this afternoon, car went into limp mode (very distinct lack of power). The whistle is now only a low pitched hum.
Vag com'd the car this evening and have:
Control Module Part Number: 8D0 907 551 K
Component and/or Version: 2.7l V6/5VT G 0001
Software Coding: 10711
Work Shop Code: WSC 00016
Additional Info: WUAZZZ8DZ1N902755 AUZ7Z0Y1651951
3 Faults Found:
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - - Intermittent
16687 - Cylinder 3: Misfire Detected
P0303 - 35-10 - - - Intermittent
17965 - Charge Pressure Control: Positive Deviation
P1557 - 35-00 -
I take it my problem is related to 17965?!
I haven't covered more than 50 miles since the whistle started.
Any opening thoughts on what I might be in for?
I'm obviously loathed to think 'new turbos' and hoping that it'll be a simple leak or value or something. But I have a feeling I'm dreaming. Will a turbo really go from working just fine to seriously not working in under 50 miles?
Audi B5 RS4 Standard. Avus Silver. Debadged. Supaglass.
Contigo
RE: Turbo whistle, limp mode, VAGCOM codes.... what am I in
Post by Contigo » Mon Jan 26, 2009 12:01 am
Boost leak mate, I'd say.
I had same one's on mine, in fact one sec lemme search.
Here you go, this is what I had on mine when mine started whistling and going into limp mode
VAG com results
VAG-COM Version: Release 311.2-N
Work Shop Code: WSC 63351
Additional Info: WUAZZZ8DZ1N903748 AUZ7Z0Y1754948
4 Faults Found:
P1557 - 35-10 - - - Intermittent
P0300 - 35-00 - -
16685 - Cylinder 1 Misfire Detected
P0301 - 35-00 - -
16689 - Cylinder 5 Misfire Detected
P0305 - 35-00 - -
Drive it to Doug and get it sorted, keep revs low and you'll be sorted.
2001 Avus Silver RS4 B5 60k on clock, MRC Custom Remap, Sunroof, Bluetooth prep
2006 Daytona Grey RS4 B7, RNS-E - SOLD
2006 BMW M6 - GONE
grizz
Post by grizz » Mon Jan 26, 2009 12:05 am
Don't run the car with any boost ! ! ! Disconnect your n75 valve, It's under the little left carbon engine cover , it's got a brown plug on it . Get it pressure test. as soon as you can .
There are several members in London who will help. Good luck ... Grizz
Unit 20
0151 3366888
mylife98
Post by mylife98 » Mon Jan 26, 2009 1:51 pm
Cheers contigo and grizz.
Well I’m fingers crossed it’s boost leak and not turbo.
Thanks for the tip on disconnecting the N75 value. However, decided that since I’m a good 70 miles from my garage and I’ve got RAC cover, I’d make use of the RAC and get them to pick the car up and drop it at my garage. Least risk of causing any (more?) damage I figure.
Spoke to my mechanic. If after he’s looked at it, it proves to be the turbo (which I understand is engine out to replace – and replace both), then I’ll probably bring forward the 80k cambelt change (currently 67k on clock) and do the whole lot in one go. That’ll be a couple of grand I wasn’t planning on spending this month! :cry:
If it is the turbo, any good recommendations for either new turbos or refurbishing of my current ones? (Keen to keep the car stock factory spec btw, so I’m not thinking upgrades).
I’ll keep you posted on the diagnosis.
Many thanks!
Contigo
Post by Contigo » Mon Jan 26, 2009 1:57 pm
I doubt it's turbo's but you never know for sure. Ask them to connect it up to the pressure hose and test for leaks, best hope they know what they are doing. I'd be more inclined to take it to MRC in Banbury to get it looked at and whilst there get new MAF, N75 and health check too.
2006 BMW M6 - GONE
S25MRS
Post by S25MRS » Mon Jan 26, 2009 6:04 pm
Has the price to s&f new turbos dropped at all, or is it the same as it used to be, give or take? Just that "a couple of grand I hadn't intended to spend this month" seems optomistic if it's new turbos...... sorry
Mark
Current:
B6 S4 Avant
CBR1000RR-8
Gone:
2001 RS4
MV Agusta F4
S4
Post by S4 » Mon Jan 26, 2009 6:44 pm
I hope he really knows his way round the car. as not many do.
mylife98
Post by mylife98 » Mon Jan 26, 2009 8:34 pm
Yep, I’m in the fortunate position of having a great garage/mechanic who I trust. 15yrs ex Audi/VW and sees a lot of the B5 RS4s (looks after the stock of one of our major traders in the B5 RS4s). Certainly hasn't let me down yet.
More than a couple of grand?! Ouch. Does any one know how much new Audi OEM turbos are?
I was trying to get a feel for things today cost wise. A quick Google takes me to Audi Turbochargers. £728+VAT each new or recondition my turbos from £248-548+VAT depending on state/damage etc.
Labour for engine in/out obviously won’t be pleasant. Anyone know the Audi estimate for doing that? If I was guessing I’d be thinking a day out and another day to put back (16hrs total), but that’s a complete guess.
Car was delivered courtesy of a RAC low-loader at 5:30 today.
I await the phone call sometime tomorrow/Wednesday.
Damn stiff drink when I get home this evening!
S25MRS
Post by S25MRS » Mon Jan 26, 2009 9:08 pm
Sorry, didnt want to cause you any concern, but IIRC, to supply & fit both turbos was in the region of £3000-£3500, or am I completely way out with these figures? My worry about that bill was a reason I got out of my RS.
Like the advice above, suggest ringing a few folks, especially the guys mentioned on here on here.
You wait, I'm trying (not intentionally) to get you worried and all it'll be is a leak from a hose :)
Mark
Current:
B6 S4 Avant
CBR1000RR-8
Gone:
2001 RS4
MV Agusta F4
grizz
Post by grizz » Mon Jan 26, 2009 9:24 pm
That's about right for two new turbos & fitting.
Unit 20
0151 3366888
S25MRS
Post by S25MRS » Mon Jan 26, 2009 9:26 pm
Cheers Grizz - I was starting to think the old memory wasn't like it was.......assuming that comment was aimed at me!?
Mark
Current:
B6 S4 Avant
CBR1000RR-8
Gone:
2001 RS4
MV Agusta F4
dhali
Post by dhali » Mon Jan 26, 2009 11:14 pm
S25MRS wrote:Sorry, didnt want to cause you any concern, but IIRC, to supply & fit both turbos was in the region of £3000-£3500, or am I completely way out with these figures? My worry about that bill was a reason I got out of my RS.
Many on here have suggested setting up seperate fund aside incase of this.
GregorFuk
Post by GregorFuk » Tue Jan 27, 2009 1:29 pm
This and the cam wear issue is the reason I've just coughed up for a warrantee.
Contigo
Post by Contigo » Tue Jan 27, 2009 3:12 pm
Yep thinking bout going back to mine with WD. Who you use GregorFuk?
2006 BMW M6 - GONE
derdle
Post by derdle » Tue Jan 27, 2009 5:10 pm
The misfire codes could well be that the spark plugs are slightly loose.
As for the charge pressure, as others have said it is almost certainly a boost leak. I suppose there is every chance that the turbos are ok.
For information, Audi replaced mine under warranty 4 years ago and it cost just shy of £5k with internal discount!
Paul
Users browsing this forum: No registered users and 104 guests
