Got my filter and new oil to chuck in but no longer have access to ramps so going to attempt to do the oil and filter change just by jacking the car up and using axle stands.
I know the sump plug is easy to get to as the last owner didnt tighten it up after the oil change, thankfully I noticed the oil leak and tightened it before all the oil dumped onto the motorway! Is the filter easy enough to get to and just to clarify is it the metal screw on type?
Cheers,
Russ
Oil change easy enough without using a lift/ramp?
Evo VIII long gone
B5 S4 Avant long gone
Astra CDTI estate with 2 blown gearboxes long gone
BMW M Sport 320d Business Edition tourer the chariot of choice (with DMF about to die) gone
B8 S4 Avant is now the chariot of choice
philipwalker
- 5th Gear
RE: Oil change easy enough without using a lift/ramp?
Just getting the undertray of while rolling around in a puddle can be a bit of a pain in the ass
Re: RE: Oil change easy enough without using a lift/ramp?
Had that off beore in the past when said previous owner left the sump plug undone as I thought I had a major oil leak!! As it happens the cars parked in my pub car park at the mo with the nearside inner arch missing anyway as I replaced the headlight washer pump today as I had a leak.philipwalker wrote:Just getting the undertray of while rolling around in a puddle can be a bit of a pain in the ass
Is the filter easy to get to?
Evo VIII long gone
RE: Re: RE: Oil change easy enough without using a lift/ramp
If I remember right it's pretty much right near the sump plug, easy enough to get to.
Re: RE: Re: RE: Oil change easy enough without using a lift/
Nice, thanking youstapo69 wrote:If I remember right it's pretty much right near the sump plug, easy enough to get to.
Evo VIII long gone
