Changed the battery a few days ago after an unexpected failure. The S4 has a couple of problems since.
Air bag light comes on after about 4 miles, goes out again when ignition is turned off and on again.
The #1 trip computer has dissapeared completly, #2 is there, but when i try to scroll through to get trip 1 data, its not there at all.
I did perform the Key syncro after fitting the new battery, so everything else is fine.
Any thoughts is it a trip to the dealer or purchase VAG.COM.
S4 2003-b6
Cheers Steve
Problems after battery change
- BlingBling
RE: Problems after battery change
Vag-com is probably the answer but avoid a trip to the stealers. Have a look on the Vag-com board for someone in your area and ask them if they can help. Probably cost you a few beers.
