Afternoon all,
Was hoping to pick your brains as my ABS light and the tractions control light seems to turn itself on either after heavy breaking or when the car has been sat in traffic on and off the brakes when the car is constantly in drive. If i keep flicking the box out of drive into neutral whilst in traffic is doesn't seem to do it......I know the discs are going to need doing v soon although the computer warning as not highlighted this yet as it used to in my old S3....any thoughts? Really appreciate your help.
Warning lights
tartan_rob
RE: Warning lights
VAG-com mate. it is the best place to start.
2017 Kawasaki Z1000
2014 RS6
2014 S1
2014 RS6
2014 S1
RE: Warning lights
Hi Zimzzimmer,
Could well be your brake light switch as Rob has said VAG-COM will indicate this. This was the case with mine and the part was about £8 and took me about 15mins to fit, just a bit fiddly......
Lig.
Lig.
RE: Warning lights
same with mine a few months ago, warning trangle on dash came on every now and then, turned out to be brake light switch.
RE: Warning lights
ditto have had exactly same problem turned out to brake light switch, a cheap fix thankfully
RS6 Avant, black with black wheels, front S6 led lights, rear smoked Led lights, miltek non-res, miltek cat by-pass down pipes, ITG air filters, H&R kit with Arb's, MRC stage 2
Zimzzimmer
