Talk about luck
2.7 V6 30v biturbo - 380 bhp
rs4boy
Talk about luck
Post by rs4boy » Mon Dec 15, 2008 7:29 pm
Driving home today bmw m3 all over me i let him pass as my car was a bit cold, then he slow down back to the side of me, so he wanted to play. I know i should not of as i say the car was a bit cold but i could not help my self, i gave it the beans and the clutch just slipped alot, backed off and the clutch pedal was on the floor, it was hard to get out of gear so i pulled over to have a look could not see anything just burning clutch smell, got back in the car and the pedal had come up a bit. So i drove home slowly, on the way home over the time it took to get home the clutch pedal came up a bit at a time until by the time i was home the pedal was back to wear it should be. Has anyone had this or know anything about this.
Regards
Jason
Spunbigendbearing
Post by Spunbigendbearing » Mon Dec 15, 2008 9:03 pm
I had a similar thing many years ago with a golf VR6;pressed the clutch one morning to put it in first and it stayed there,coming up a bit after a while.
Turned out to be a leaking hydraulic cilinder.
Sql_RS4
Post by Sql_RS4 » Mon Dec 15, 2008 10:41 pm
It happened to me and my friend too.
You slip the clutch, it burns and stays pushed. Then comes back to normal.
Norrs2
Post by Norrs2 » Tue Dec 16, 2008 12:37 pm
Definately Clutch Slave Cylinder or Master Cylinder. Seals are leaking.
B5 RS4 - Santorin Blue Pearl
B7 Brakes
MRC Custom Re-Map
Loba Camshafts
Wagner Downpipes
Miltek Cat Back SS Exhaust
1988 Pearl White MB Ur quattro (Genesis)
rs4boy
Post by rs4boy » Tue Dec 16, 2008 6:42 pm
Thanks chaps
I will book it in to MRC then.
Jason
rs4boy
Post by rs4boy » Thu Jan 08, 2009 5:56 pm
Just to let you chaps know it was the pressure plate which was the cause of the problem, but when the gear box was out i had the clutch changed as well. So thanks again to MRC
Jason
Virdee Autos
Trader (Expired)
Post by Virdee Autos » Thu Jan 08, 2009 7:49 pm
Glad to hear you got it sorted
Did you go for the stock one in the end?
Virdee Autos ~ 07950-526592
rs4boy
Post by rs4boy » Fri Jan 09, 2009 6:19 pm
Cheers Virdee
Stayed with the stock clutch i think its good for what i need.
I now have no money left thought :(
Jason
Users browsing this forum: Bing [Bot] and 146 guests
