Brake advise
Commencal
Brake advise
Post by Commencal » Fri Nov 14, 2008 2:07 pm
Hi am after a bit of advice regarding rear brakes for the S4 B6,
am currently running a B5 S4 and am looking at upgrading the rear brakes to B6 spec, am finding conflicting info as to whether the facelift B5 alloy rear calipers are the same as B6, if so then what is the caliper bracket and pad numbers to allow me to upgrade, realise that i will need new hoses and may have to play around with the handbrake cable routing to get it all to fit. Any help before i start spending money would be appreciated.
caliper to slide bolt spacing on the B5 caliper is 90mm if that helps.
do the following part number seem right.
Carrier 8E0615425B
Pad 8E698451C
pad springs 3D0615231
Cheers Paul
Users browsing this forum: No registered users and 109 guests
