PI$$ED:-Creaky Front Left Corner
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
Trig
Post by Trig » Mon Nov 03, 2008 10:51 pm
Had a creak/squeak on the O/S front orner now for a month!
It does it when you turn and/or when you bounce on the wing.
Thought I had sorted it but came back after 2 days.
Removed the 2 top arms and the track rod and everything seems fine here.
When you jack it up to remove the wheel and have a look, it goes away.
The only thing I can think it is, is the spring on the strut.
Do thre front springs break???
Anyone else had this?
I need help before the thing drives me insane :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil:
Philws4
Post by Philws4 » Tue Nov 04, 2008 9:40 pm
Check the Xenon auto levelling sensor under the wheel arch :wink:
B5 S4
craigg
Post by craigg » Wed Nov 05, 2008 9:57 am
any spring can break, but creaking is often a sign of worn rubber bushes in the control arms.
Trig
Post by Trig » Wed Nov 05, 2008 10:12 pm
Philws4 wrote:Check the Xenon auto levelling sensor under the wheel arch :wink:
Done that and that was creaking but now it aint bolted on it has got worse!!
Are the bottom arm bushes 'hydraulic'? EG Oil filled.
Trig
Post by Trig » Wed Nov 05, 2008 10:14 pm
Philws4
Post by Philws4 » Wed Nov 05, 2008 10:23 pm
Not as far as i know, think they are just 'dry' rubber push in bushes.
B5 S4
Mikey-S
Post by Mikey-S » Thu Nov 06, 2008 12:37 am
Get yourself a mechanics stethascope. These are really good at pinpointing creaks and knocks etc. Basically it just does the same thing as a long screwdriver placed in contact with your ear and the source of the noise.
Highly recommended.
Trig
Post by Trig » Fri Nov 07, 2008 8:24 pm
Right,
Had a bloody good look round it this afternoon and found that BOTH bottom ball joints have play in them and it is that that creaks when you turn the wheel or the sus. goes up and down.
Pulled back the rubber boots and 'lubed' them up and no more noise, but these will need replacement.
My questions are
Does anyone know the part no's of the 2 lower arms?
Are these the same as A4 items?
Where is best to buy from?
Trig
Post by Trig » Fri Nov 07, 2008 9:15 pm
Someone on here bought a complete kit from somewhere.(USA I think)
Anyone remember who it was or where it was from?
craigg
Post by craigg » Fri Nov 07, 2008 11:33 pm
i fitted new arms to the front of mine when i baught it.
I used a Meyle kit for an A4 i baught from german ebay. Cost about £260-270 incl delivery:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0292061797
They are upgraded over the stock audi parts, with larger balljoints and seem to get a good writeup, plus they're a lot cheaper than the OE ones, and it really tightened up the suspension changing them all.
The S4 and A4 parts have different part numbers on vagcat, but the difference is a slight change in the rubber bushes, and from what i saw when fitting them, the Meyle bushes look more sturdy than the OE S4 ones that came off so i wouldnt worry too much about the difference.
Trig
Post by Trig » Sat Nov 08, 2008 10:56 am
craigg
Post by craigg » Sat Nov 08, 2008 1:48 pm
those are A8 arms?
The A4 ones are still the same price!
Trig
Post by Trig » Sat Nov 08, 2008 6:16 pm
Erm... DOH! :oops: :oops: :oops: :oops: :oops:
Users browsing this forum: No registered users and 161 guests
