Any help with the following
17916
16500
17967
Read the description but doesn't mean anything.
Anyone hlp in 'english' please.( Make it easy for an idiot to understand!!)
DTC Codes Help needed
RE: DTC Codes Help needed
From the Ross-Tech Wiki:
First one 17916 speaks to restricted airflow maybe due to some sort of obstruction in the air intake system.
Second one: engine coolant sensor faulty.
Third one: some sort of throttle body problem.
Typically with these sorts of report, one failure causes a number of fault reports. Without knowing more it is hard to diagnose as we could do with hearing more:
1. What's your vehicle type/
2. Have any symptoms??
3. Any warning lights illuminated?
4. Any unusual readings - temperatures etc?
If no symptoms, then i would clear the codes and give the car a few mile drive ensuring it's fully warmed up. Then re-diagnose to see what fault reports you have. Definitely worth doing to make sure you don't start dismantling the car before you know there is a real problem. Sometimes a small one-off intermittent fault happens which triggers a slew of reports.
Users browsing this forum: No registered users and 26 guests
