I understand there is a method of confirming the mileage on a RS6 by confirming ECU mileage?
Does any one know how i can do this with VAG COM?
Bobby
ECU mileage confirmation
Bobby_singh
RE: ECU mileage confirmation
There is a counter which logs how many times the ECU has been flashed on VAG ecu's
But afaik, theres no counter for mileage verification... or at least not with VAGCOM
Vagcom has the option, from the main screen click on applications then you will see Display mileage.
There you go. Good luck.
http://www.ross-tech.com/vag-com/tour/a ... creen.html
Blue_Thunder
- Top Gear
It only shows KM's I think
Bobby_singh
Thanks for the replies guys - but the guy sold the car even though i put money it - pi$$ed on fire i tell ya. Apparently someone offered him more money.....ahhhhhh
Golf TDI 220hp http://uk-mkivs.net/forums/t/193610.aspx
with vdcs, go to instruments (17) grouop 50, field 1. that is the ecu mileage. it can be changed, but ony with a code from the factory.
Users browsing this forum: Google [Bot] and 109 guests
