hi,
quite a while ago i removed my rnsd unit and after plugging it all back i cannot get any radio stations. i scanned with vagcom and got the following code:
00856, so i checked Rosstech wiki and found the following.
00856 - Radio Antenna: Open Circuit
00856 - Radio Antenna: Short to Ground
Possible Symptoms
* Radio Tuner not working
Possible Causes
* Wiring/Connectors from/to Radio Antenna faulty
* Radio Antenna faulty
Possible Solutions
* Check Wiring/Connectors from/to Radio Antenna
* Check Radio Antenna
i have checked and double checked ALL the connections at the BACK of the unit (these are the ONLY ones i have disconnected) and it still dosnt work . Would be grateful if someone can tell me what ELSE to check.
TIA.
00856??
- 2nd Gear
RE: 00856??
As the instructions say did you checked the wiring itself? Even though you double checked the connectors, there is no guarantee that the wiring itself is OK.
BTW: The WIKI content is continuously updated and enhanced, therefor we'd appreciate if you linked to the WIKI instead of copying the content. Thanks.
Sebastian @ Ross-Tech.com
Users browsing this forum: No registered users and 23 guests
