204 bhp !!! Need new MAF ?
Just got my car on the dyno and it made a hugely impressive 204 bhp at the flywheel (154 at the wheels)
It was suggested a new MAF would be the solution.
Is this likely and how much would a new MAF cost ?
Blue_Thunder
- Top Gear
RE: 204 bhp !!! Need new MAF ?
Very difficult to say without knowing if you've run vagcom checks or not.
The problem could very well be the MAF, but then again it could be a whole host of other sensors which have failed.
Try running the car with the MAF disconnected to see if it runs better.
Re: RE: 204 bhp !!! Need new MAF ?
I've not run the VAG com as I don't own the equipment.Blue_Thunder wrote:Very difficult to say without knowing if you've run vagcom checks or not.
The 'OK' light comes on when you start the car but I'm not sure exactly what this measures.
Blue_Thunder
- Top Gear
RE: Re: RE: 204 bhp !!! Need new MAF ?
The 'OK' thing only checks ABS and fluid levels I think. Try unplugging the MAF and go for a drive.
could be an egt fault making the car run in limp mode
Blue_Thunder
- Top Gear
Or a lambda sensor or a faulty N75 or a knackered DV or a boost leak or or or....
- mikeyquattro
- Top Gear
MGR, whre are you? Someone in your area may have Vagcom and be able to help
Tomorrow is another day
I've just unplugged the MAF. The warning lights appeared on the dash so it was not connected.
It seemed almost the same as with it connected.
The rolling road measured the fuel ratio and it was 14.4 throughout the entire rev range.
I'm in wokingham (berkshire)
I think the car must be running in the limp home mode for some reason. Theres not much boost happening.
- mikeyquattro
- Top Gear
Look here
http://rs246.com/index.php?name=PNphpBB ... ic&t=51359
TWH is in Bracknell and has Vagcom. Others in Reading.....
Thanks for that, I've sent some PMs !mikeyquattro wrote:Look here
Hi,
Sorry to hi-jack the thread, I'm relatively new here, just got an S4. Before I plan a trip up to MRC, is there someone local who can offer their VAG-COM services to me? Just to make sure everything is ok. I do plan on heading up to MRC for a remap, but not for a few weeks as I've just paid for insurance and holiday etc!
I'm based near Lymington in the New Forest, half way between Southampton and Bournemouth.
Thanks,
Dan
Sorry, just seen the VAG-COM register sticky. Dam newbies!
Thanks,
Dan
Thanks for the offer, I'll let you know as a few others have also been in touch (thanks guys) so I'll find out whats the best solution for everyone.HibS4 wrote:MGR
I'm in Thatcham, although I could meet you at Savacentre in Calcot if you wanted to run Vagcom on your car.
Glen
That would be a good option for me however. Just waiting for a few people to get back to me.
tartan_rob
Users browsing this forum: No registered users and 97 guests
