Slow wipers on a B6??
S25MRS
Post by S25MRS » Wed Sep 17, 2008 8:28 am
anyone had an issue with their B6? Did a quick search and couldn't see anything immediately - wipers started moving REALLY slowly, then almost stopped completely...... wondered if this was same thing that affects B5 cars?Anyone help shed some light please?
Mark
Current:
B6 S4 Avant
CBR1000RR-8
Gone:
2001 RS4
MV Agusta F4
BlingBling
RE: Slow wipers on a B6??
Post by BlingBling » Wed Sep 17, 2008 10:15 am
Never heard of any issues on this. What is the problem with B5'sß
dest
Post by dest » Wed Sep 17, 2008 11:26 am
At a guess its the same thing that the A3 suffers from too!
The grease in the spindles dries up, and eventually they stop moving altogether and seize.
I got a new linkage for my g/f's A3 from Vagparts for about £35
nidfix
Post by nidfix » Fri Sep 19, 2008 10:27 am
Same as dest: the spindles of the mecanism can get rusted. they gradually slow down the engine up to the point that no move is possible.
As you cannot actually get access to the rusted area, you may have to change the entire set. It is not very expensive and you can even do it yourself.
When that happened to mine, I could not even slightly move the old one by hand.
They a bit changed the part since in order to address that issue.
For the time being, after 2 years, no problem.
I would suggest you to check it quickly: it increases the effort on the engine and if you have to replace also the engine, it will cost you much more.
dest
Post by dest » Fri Sep 19, 2008 10:46 am
I assume "engine" means motor?
As above, I would definitly get it sorted ASAP, when I took mine off after trying it, the motor was red hot due to the extra effort needed to try to move them.
A new motor is ALOT more expensive than the mechanism!
S25MRS
Post by S25MRS » Fri Sep 19, 2008 5:39 pm
Cheers guys,
A phone call to VAG Parts is in order then, once I've taken a good look - typically, it had to happen when I was in Dorset on holiday!! Thankfully, nothing but SUN SUN SUN!! for the 10 days we were there...result.
Mark
Current:
B6 S4 Avant
CBR1000RR-8
Gone:
2001 RS4
MV Agusta F4
nidfix
Post by nidfix » Sun Sep 21, 2008 1:55 pm
dest wrote:I assume "engine" means motor?
Yes "motor". I wrote too quickly and english in not my mother tongue as you can guess. :oops:
Madelvic
Post by Madelvic » Thu Sep 25, 2008 10:18 pm
Me too - started at the weekend. Search on the web - seems to be a common problem with B6 A4s too. Found a guide on how to take the mech apart. Car in bits at the moment.
See http://www.audiworld.com/tech/ and slow wiper diy fix.
Parts available if you need them from http://www.vagparts.com/
Macan GTS
Boxster S
Previously
Audi RS4 B8
Audi S4 B8
Audi S4 B6
Nissan GTR,
Lotus Elise 111R,
Caterham,
Golf GTi Mk 1, Mk 2, Mk 3, Mk 4, VR6,
Various SAAB Turbos
Peugeot 205 GTi,
RS2000
S25MRS
Post by S25MRS » Fri Sep 26, 2008 3:12 pm
thanks bud, I sorted it earlier in the week - had to go to main stealers as VAGParts couldn't get the parts until early next week
Mark
Current:
B6 S4 Avant
CBR1000RR-8
Gone:
2001 RS4
MV Agusta F4
