can this be done with the vag tool?
or will this not work with a can bus?????
is there a way to reset it thought the dash?
cheers
will
minor service by the way,
b7 service light reset
wabtheking
4.2 V8 32V ABZ Coupe Quattro
2.8 V6 30V ACK A4 Quattro
X2 FD3S Rx-7's FOR SALE!!!!!
- BlingBling
RE: b7 service light reset
The service light on S4's can be reset on the dash. So imagine the same is possible with a RS4. It will reset the service intervals to Fixed Term. I.e. 12 months. Check the manual for instructions.
It's not in the manual
You'll need VAG-COM to switch between Long Life & Annual, but if you're after a reset -
Ignition off
Hold in the spanner button on dashboard
Turn key to ignition on (not start) while still holding the button
Finally press and hold the trip reset (0.0) button and the service interval should clear in about 5 secs
Ignition off
2007 Daytona RS4 Avant
- PetrolDave
For fixed intervals you can do it from the dash, but for AVS you have to use VAG-COM or get the dealer to do it with their VAS.
wabtheking
cheers guys, done now, miles and days goes to ../../../ but told this can take 3days or bout 300 miles to sort itself out
thanks again
will
thanks again
will
Users browsing this forum: Bing [Bot], Majestic-12 [Bot] and 166 guests
