Evap Emission Control Sys: Incorrect Flow ????
Nige_RS4
Post by Nige_RS4 » Mon Sep 08, 2008 10:46 pm
Just scanned my car and got this DTC ....
1 DTCs Found:
16825 - Evap Emission Control Sys: Incorrect Flow
35-10 - - - Intermittent
Any ideas? RossTech WiKi says;
Possible Causes
Evaporative Emission (EVAP) Canister Purge Regulator Valve (N80) faulty/jammed
Evaporative Emission (EVAP) Canister Purge Solenoid Valve (N115) faulty/jammed
Evaporative Emission (EVAP) Canister Sealing faulty
Pipes between Tank Breathing and Throttle Body leaky/blocked
Possible Solutions
Check Evaporative Emission (EVAP) Canister Purge Regulator Valve (N80)
Perform Output Test
Check Evaporative Emission (EVAP) Canister Purge Solenoid Valve (N115)
Perform Basic Setting
Check Pipes between Tank Breathing and Throttle Body
Where is the EVAP canister?
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
Virdee Autos
Trader (Expired)
RE: Evap Emission Control Sys: Incorrect Flow ????
Post by Virdee Autos » Mon Sep 08, 2008 11:03 pm
I think its on the O/S wheel arch. You'll need to remove the wheel arch liner to gain access, as I remember seeing this when I had mine off.
Virdee Autos ~ 07950-526592
Return to “DTC / VCDS”
