My Rs4
My Rs4
Friday,22,August,2008,14:14:36:55700
VCDS Version: Release 805.0
Data version: 20080730
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
VIN: WUAZZZ8E87N902946 Mileage: 31240km/19411miles
Address 01: Engine Labels: 079-910-560-BNS1.lbl
Part No SW: 8E1 910 560 HW: 8E1 907 560
Component: 4.2L V8/4V FSI ª0080
Revision: --H13--- Serial number: XXXXXXXXXXXXXX
Coding: 01040003180F0160
Shop #: WSC 00155 264 91102
10 Faults Found:
012312 - Valve for Exhaust Flap 1 (N321): Short to Ground
P3018 - 002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 4
Mileage: 27555 km
Time Indication: 0
Freeze Frame:
RPM: 238 /min
Load: 83.5 %
Speed: 0.0 km/h
Temperature: 72.0°C
Temperature: 62.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 12.192 V
001112 - Evap System Purge Control Valve (N80): Short to Ground
P0458 - 002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Mileage: 27555 km
Time Indication: 0
Freeze Frame:
RPM: 238 /min
Load: 83.5 %
Speed: 0.0 km/h
Temperature: 72.0°C
Temperature: 62.0°C
Voltage: 12.192 V
008201 - Intake Manifold Flap; Bank 1: Short to Ground
P2009 - 002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Mileage: 27555 km
Time Indication: 0
Freeze Frame:
RPM: 238 /min
Load: 83.5 %
Speed: 0.0 km/h
Temperature: 72.0°C
Temperature: 62.0°C
Voltage: 12.192 V
004199 - Intake Air Switch-Over Valve (N335): Short to Ground
P1067 - 002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Mileage: 27555 km
Time Indication: 0
Freeze Frame:
RPM: 238 /min
Load: 83.5 %
Speed: 0.0 km/h
Temperature: 72.0°C
Temperature: 62.0°C
Voltage: 12.192 V
005173 - Secondary Air Pump Relay (J299): Short to Ground
P1435 - 002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Mileage: 27555 km
Time Indication: 0
Freeze Frame:
RPM: 238 /min
Load: 83.5 %
Speed: 0.0 km/h
Temperature: 72.0°C
Temperature: 62.0°C
Voltage: 12.192 V
005153 - Secondary Air Injection Solenoid Valve (N112): Short to Ground
P1421 - 002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Mileage: 27555 km
Time Indication: 0
Freeze Frame:
RPM: 238 /min
Load: 83.5 %
Speed: 0.0 km/h
Temperature: 72.0°C
Temperature: 62.0°C
Voltage: 12.192 V
005494 - Right Engine Mount Solenoid Valve (N145): Short to Ground
P1576 - 002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Mileage: 27555 km
Time Indication: 0
Freeze Frame:
RPM: 217 /min
Load: 80.0 %
Speed: 0.0 km/h
Temperature: 73.0°C
Temperature: 63.0°C
Voltage: 11.049 V
008853 - Fuel Pressure Regulator Valve (N276): Short to Ground
P2295 - 002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 3
Mileage: 29257 km
Time Indication: 0
Freeze Frame:
RPM: 230 /min
Load: 83.9 %
Speed: 0.0 km/h
Temperature: 73.0°C
Temperature: 63.0°C
Voltage: 11.049 V
000049 - Oxygen (Lambda) Sensor B1 S1: Heating Circuit: Short to Ground
P0031 - 002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Mileage: 29326 km
Time Indication: 0
Freeze Frame:
RPM: 785 /min
Load: 29.0 %
Speed: 6.0 km/h
Temperature: 80.0°C
Temperature: 58.0°C
Voltage: 13.843 V
000055 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit: Short to Ground
P0037 - 002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Mileage: 29326 km
Time Indication: 0
Freeze Frame:
RPM: 785 /min
Load: 29.0 %
Speed: 6.0 km/h
Temperature: 80.0°C
Temperature: 58.0°C
Voltage: 13.843 V
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 8E0-910-517.lbl
Part No SW: 8E0 910 517 G HW: 8E0 614 517 BD
Component: ESP8 quattro H06 0150
Revision: 00000000 Serial number: 00000000000000
Coding: 0004533
Shop #: WSC 06335 000 00000
No fault code found.
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 BM
Component: A4 Klimaautomat 2833
Coding: 00000
Shop #: WSC 00000
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 N
Component: int. Lastmodul ECE 0907
Coding: 00031
Shop #: WSC 06335
Address 11: Engine II Labels: 079-910-560-BNS2.lbl
4 Faults Found:
005490 - Left Engine Mount Solenoid Valve (N144): Short to Ground
P1572 - 002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Mileage: 27555 km
Time Indication: 0
Freeze Frame:
RPM: 234 /min
Load: 80.0 %
Speed: 0.0 km/h
Temperature: 73.0°C
Temperature: 63.0°C
Voltage: 11.049 V
004764 - Fuel Pressure Regulator Valve; Bank 2 (N276): Short to Ground
P129C - 002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Mileage: 29325 km
Time Indication: 0
Freeze Frame:
RPM: 231 /min
Load: 83.9 %
Speed: 0.0 km/h
Temperature: 73.0°C
Temperature: 63.0°C
Voltage: 11.049 V
000081 - Oxygen (Lambda) Sensor B2 S1: Heating Circuit: Short to Ground
P0051 - 002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Mileage: 29326 km
Time Indication: 0
Freeze Frame:
RPM: 783 /min
Load: 29.0 %
Speed: 6.0 km/h
Temperature: 80.0°C
Temperature: 58.0°C
Voltage: 13.843 V
000087 - Oxygen (Lambda) Sensor B2 S2: Heating Circuit: Short to Ground
P0057 - 002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Mileage: 29326 km
Time Indication: 0
Freeze Frame:
RPM: 783 /min
Load: 29.0 %
Speed: 6.0 km/h
Temperature: 80.0°C
Temperature: 58.0°C
Voltage: 13.843 V
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 G HW: 8E0 959 655 G
Component: Airbag 9.41 H12 3730
Revision: 91H12373 Serial number: 0036M0G3BCL8
Coding: 0430612
Address 16: Steering wheel Labels: 8E0-953-549-T.lbl
Part No: 8E0 953 549 T
Component: Lenksáulenmodul 0301
Coding: 06021
Shop #: WSC 06335
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 931 G HW: 8E0 920 931 G
Component: KOMBI+WFS 4 H14 0040
Revision: 0040 Serial number: 00000000000000
Coding: 0023111
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8E0 035 192 K HW: 8E0 035 192 K
Component: RNS-E HIGH EU H72 0650
Revision: 01S Serial number: AUZBZ7F1181507
Coding: 0309713
Shop #: WSC 02195 785 00200
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 CH
Component: Komfortgerát T3B 4135
Coding: 06762
Shop #: WSC 06335
Part No: 8E1959801G
Component: Tõrsteuer.FS BRM 0706
Part No: 8E1959802G
Component: Tõrsteuer.BF BRM 0706
Part No: 8E0959801E
Component: Tõrsteuer.HL BRM 0606
Part No: 8E0959802E
Component: Tõrsteuer.HR BRM 0606
2 Faults Found:
00962 - Alarm via. Tilt Sensor
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
Address 55: Xenon Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 F
Component: Dynamische LWR H02 0010
Revision: 00000001 Serial number:
Coding: 0000005
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0309713
Address 65: Tire Pressure Labels: 8E0-907-273.lbl
Part No SW: 8E0 907 273 A HW: 8E0 907 273 A
Component: Reifendruck 3 H04 0130
Coding: 0022523
Shop #: WSC 02197 785 00200
Address 76: Park Assist Labels: 8E0-919-283-8EC.lbl
Part No SW: 8E0 919 283 E HW: 8E0 919 283 E
Component: Parkhilfe 8-Kan H06 0010
Revision: 00H06000 Serial number: 00067802120624
Coding: 0000104
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P0 862 335 Q HW: 8P0 862 335 K
Component: FSE_255x BT H26 0350
Revision: 00000000 Serial number: 00000005147235
Coding: 0011544
Shop #: WSC 00000 000 00000
End ---------------------------------------------------------------------
69 75 76 77
10 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Mileage: 27555 km
Time Indication: 0
Freeze Frame:
RPM: 238 /min
Load: 83.5 %
Speed: 0.0 km/h
Temperature: 72.0°C
Temperature: 62.0°C
Voltage: 12.192 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Mileage: 27555 km
Time Indication: 0
Freeze Frame:
RPM: 238 /min
Load: 83.5 %
Speed: 0.0 km/h
Temperature: 72.0°C
Temperature: 62.0°C
Voltage: 12.192 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Mileage: 27555 km
Time Indication: 0
Freeze Frame:
RPM: 238 /min
Load: 83.5 %
Speed: 0.0 km/h
Temperature: 72.0°C
Temperature: 62.0°C
Voltage: 12.192 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Mileage: 27555 km
Time Indication: 0
Freeze Frame:
RPM: 238 /min
Load: 83.5 %
Speed: 0.0 km/h
Temperature: 72.0°C
Temperature: 62.0°C
Voltage: 12.192 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Mileage: 27555 km
Time Indication: 0
Freeze Frame:
RPM: 238 /min
Load: 83.5 %
Speed: 0.0 km/h
Temperature: 72.0°C
Temperature: 62.0°C
Voltage: 12.192 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Mileage: 27555 km
Time Indication: 0
Freeze Frame:
RPM: 238 /min
Load: 83.5 %
Speed: 0.0 km/h
Temperature: 72.0°C
Temperature: 62.0°C
Voltage: 12.192 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Mileage: 27555 km
Time Indication: 0
Freeze Frame:
RPM: 217 /min
Load: 80.0 %
Speed: 0.0 km/h
Temperature: 73.0°C
Temperature: 63.0°C
Voltage: 11.049 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 3
Mileage: 29257 km
Time Indication: 0
Freeze Frame:
RPM: 230 /min
Load: 83.9 %
Speed: 0.0 km/h
Temperature: 73.0°C
Temperature: 63.0°C
Voltage: 11.049 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Mileage: 29326 km
Time Indication: 0
Freeze Frame:
RPM: 785 /min
Load: 29.0 %
Speed: 6.0 km/h
Temperature: 80.0°C
Temperature: 58.0°C
Voltage: 13.843 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Mileage: 29326 km
Time Indication: 0
Freeze Frame:
RPM: 785 /min
Load: 29.0 %
Speed: 6.0 km/h
Temperature: 80.0°C
Temperature: 58.0°C
Voltage: 13.843 V
Coding: 0004533
Coding: 00000
Shop #: WSC 00000
Coding: 00031
Shop #: WSC 06335
4 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Mileage: 27555 km
Time Indication: 0
Freeze Frame:
RPM: 234 /min
Load: 80.0 %
Speed: 0.0 km/h
Temperature: 73.0°C
Temperature: 63.0°C
Voltage: 11.049 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Mileage: 29325 km
Time Indication: 0
Freeze Frame:
RPM: 231 /min
Load: 83.9 %
Speed: 0.0 km/h
Temperature: 73.0°C
Temperature: 63.0°C
Voltage: 11.049 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Mileage: 29326 km
Time Indication: 0
Freeze Frame:
RPM: 783 /min
Load: 29.0 %
Speed: 6.0 km/h
Temperature: 80.0°C
Temperature: 58.0°C
Voltage: 13.843 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Mileage: 29326 km
Time Indication: 0
Freeze Frame:
RPM: 783 /min
Load: 29.0 %
Speed: 6.0 km/h
Temperature: 80.0°C
Temperature: 58.0°C
Voltage: 13.843 V
Coding: 0430612
Coding: 06021
Shop #: WSC 06335
Coding: 0023111
Coding: 0309713
Coding: 06762
Shop #: WSC 06335
Part No: 8E1959801G
Part No: 8E1959802G
Part No: 8E0959801E
Part No: 8E0959802E
2 Faults Found:
35-00 - -
35-00 - -
Coding: 0000005
Coding: 0309713
Coding: 0022523
Coding: 0000104
Coding: 0011544
- PetrolDave
RE: My Rs4
Lots of intermittents on the engine at low engine rpm - try clearing them and seeing if they come back.
The central convenience one just means the alarm has been triggered at some time, just clear it.
RE: My Rs4
yep. I did and after few miles come up again. however as you said nothing really important.
RE: My Rs4
Odd that many seem to be at starter motor rpm? Was this the case second time they occurred?
I am NO expert, but given some of them i might have expected the yellow engine warning light to have illuminated in the instrument binnacle?
Assume you don't have a dodgy battery?
RE: My Rs4
Friday,31,October,2008,19:21:24:55700
VCDS Version: Release 805.1
Address 01: Engine
Control Module Part Number: 8E1 910 560
Component and/or Version: 4.2L V8/4V FSI ª0080
Software Coding: 01040003180F0160
Work Shop Code: WSC 00155
11 Faults Found:
Freeze Frame:
Fault Status: 01100010
Fault Priority: 0
Fault Frequency: 4
Mileage: 40199 km
Time Indication: 0
Freeze Frame:
RPM: 300 /min
Load: 74.1 %
Speed: 0.0 km/h
Temperature: 101.0°C
Temperature: 68.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 10.795 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Mileage: 40199 km
Time Indication: 0
Freeze Frame:
RPM: 300 /min
Load: 74.1 %
Speed: 0.0 km/h
Temperature: 68.0°C
Voltage: 10.795 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Mileage: 40199 km
Time Indication: 0
Freeze Frame:
RPM: 300 /min
Load: 74.1 %
Speed: 0.0 km/h
Temperature: 68.0°C
Voltage: 10.795 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Mileage: 40199 km
Time Indication: 0
Freeze Frame:
RPM: 300 /min
Load: 74.1 %
Speed: 0.0 km/h
Temperature: 68.0°C
Voltage: 11.684 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Mileage: 40199 km
Time Indication: 0
Freeze Frame:
RPM: 300 /min
Load: 74.1 %
Speed: 0.0 km/h
Temperature: 68.0°C
Voltage: 11.684 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Mileage: 40199 km
Time Indication: 0
Freeze Frame:
RPM: 300 /min
Load: 74.1 %
Speed: 0.0 km/h
Temperature: 68.0°C
Voltage: 11.684 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Mileage: 40199 km
Time Indication: 0
Freeze Frame:
RPM: 300 /min
Load: 74.1 %
Speed: 0.0 km/h
Temperature: 68.0°C
Voltage: 11.684 V
000135 - Fuel Rail/System Pressure: Too Low
P0087 - 002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Mileage: 40253 km
Time Indication: 0
Freeze Frame:
RPM: 867 /min
Load: 25.9 %
Speed: 0.0 km/h
Temperature: 44.0°C
Temperature: 32.0°C
Voltage: 13.970 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 3
Mileage: 40253 km
Time Indication: 0
Freeze Frame:
RPM: 737 /min
Load: 34.9 %
Speed: 0.0 km/h
Temperature: 60.0°C
Voltage: 13.716 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 3
Mileage: 40254 km
Time Indication: 0
Freeze Frame:
RPM: 737 /min
Load: 34.9 %
Speed: 0.0 km/h
Temperature: 60.0°C
Voltage: 13.716 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Mileage: 40278 km
Time Indication: 0
Freeze Frame:
RPM: 1500 /min
Load: 24.7 %
Speed: 0.0 km/h
Temperature: 68.0°C
Voltage: 11.938 V
Address 01: Engine
11 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Mileage: 40199 km
Time Indication: 0
Freeze Frame:
RPM: 300 /min
Load: 74.1 %
Speed: 0.0 km/h
Temperature: 68.0°C
Voltage: 10.795 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Mileage: 40199 km
Time Indication: 0
Freeze Frame:
RPM: 300 /min
Load: 74.1 %
Speed: 0.0 km/h
Temperature: 68.0°C
Voltage: 10.795 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Mileage: 40199 km
Time Indication: 0
Freeze Frame:
RPM: 300 /min
Load: 74.1 %
Speed: 0.0 km/h
Temperature: 68.0°C
Voltage: 10.795 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Mileage: 40199 km
Time Indication: 0
Freeze Frame:
RPM: 300 /min
Load: 74.1 %
Speed: 0.0 km/h
Temperature: 68.0°C
Voltage: 11.684 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Mileage: 40199 km
Time Indication: 0
Freeze Frame:
RPM: 300 /min
Load: 74.1 %
Speed: 0.0 km/h
Temperature: 68.0°C
Voltage: 11.684 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Mileage: 40199 km
Time Indication: 0
Freeze Frame:
RPM: 300 /min
Load: 74.1 %
Speed: 0.0 km/h
Temperature: 68.0°C
Voltage: 11.684 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Mileage: 40199 km
Time Indication: 0
Freeze Frame:
RPM: 300 /min
Load: 74.1 %
Speed: 0.0 km/h
Temperature: 68.0°C
Voltage: 11.684 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Mileage: 40253 km
Time Indication: 0
Freeze Frame:
RPM: 867 /min
Load: 25.9 %
Speed: 0.0 km/h
Temperature: 44.0°C
Temperature: 32.0°C
Voltage: 13.970 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 3
Mileage: 40253 km
Time Indication: 0
Freeze Frame:
RPM: 737 /min
Load: 34.9 %
Speed: 0.0 km/h
Temperature: 60.0°C
Voltage: 13.716 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 3
Mileage: 40254 km
Time Indication: 0
Freeze Frame:
RPM: 737 /min
Load: 34.9 %
Speed: 0.0 km/h
Temperature: 60.0°C
Voltage: 13.716 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Mileage: 40278 km
Time Indication: 0
Freeze Frame:
RPM: 1500 /min
Load: 24.7 %
Speed: 0.0 km/h
Temperature: 68.0°C
Voltage: 11.938 V
RE: My Rs4
Any idea?
RE: My Rs4
How does the car drive?
- PetrolDave
RE: My Rs4
There's lots of "Short to Ground"s there.
Does the engine run OK?
Do you have any weird electrical symptoms like blowing bulbs, etc?
I notice the faults are all on ECU 1, none from ECU2. I'm wondering if you have a faulty ECU.
RE: My Rs4
The only sympton I have when i turn it on "immediately".
It takes a while and the EPC light remain on for a couple of minutes; the engine runs in fits and starts.
After several minutes the EPC ligh turn it off itself and everything is fine as before.
I'm quite confused, these are the same short to ground of this summer when the car was at 20000km, now is 40.
I'll check it out monday at the shop.
Keep you posted.
Keep you posted.
- AndrewRS4Avant
Re: My Rs4
Hi I have exactly the same sequence of 8 codes, did you find what the problem was? I am about to get the ECU box open and check fuses and for water ingress.
Thanks!
Andrew
Thanks!
Andrew
- daytonamart
- 5th Gear
Re: My Rs4
Andrew, I'm impressed with your optimism. This thread is 9 years old and the OP hasn't been active for 8 years.
Gone B7 RS4 Sprint Blue Avant
Gone B7 A4 Reflex Silver
Users browsing this forum: No registered users and 71 guests
