UK B5 cent lock codes
VenomAuzS4
Post by VenomAuzS4 » Mon Aug 18, 2008 6:27 pm
Have recently been playing around with the codes for options with the central locking.
I used the coding posted on a thread which detailed how to do this.
I have had problems getting the windows up option with key lock to work although it did once.
I've also noticed a discrepancy between my original code and the code written on the page.
Does anyone know if the US and UK codes are different and where I can get a list of all modification values for research into options I can have?
Would also be good if there was a set list for different cars as my S4 B5 would be different from my friends Mk5 Golf GTi if u know what I mean....
PetrolDave
RE: UK B5 cent lock codes
Post by PetrolDave » Tue Aug 19, 2008 11:10 am
Bluebrakes
Post by Bluebrakes » Tue Aug 19, 2008 12:35 pm
Download this little decoding program. Enter your original/modified code, tick the features you want and it will give you the new code.
http://www.kevin-st.co.uk/tt/codes.htm
Why do they call it rush hour when nothing moves!?!
Standard S4, but not for long.
PetrolDave
Re: RE: UK B5 cent lock codes
Post by PetrolDave » Tue Aug 19, 2008 2:20 pm
Bluebrakes wrote:Download this little decoding program. Enter your original/modified code, tick the features you want and it will give you the new code.
I don't think that applies to the B5?
VenomAuzS4
Post by VenomAuzS4 » Tue Aug 19, 2008 8:05 pm
Sweet... That program seems to work for B5's as it simply adjusts whatever code is in there due to binary logging. Shame there's not more codes or applications u can use it for.
Return to “DTC / VCDS”
