Newb with rear disc query!
2.7 V6 30v biturbo - 380 bhp
RS4_Schumi
Post by RS4_Schumi » Sun Aug 17, 2008 3:17 pm
Gents,
Have my B5 about a month now and just had a query about my rear brakes. I included a couple of pics which show the uneven wear on both right and left rear discs. Local mechanic thinks that it's because it wasn't driven for a while before I bought it and that it should clear up. If it's not going to clear up then what are the best cost/benefit options for me - switch to one of the alternative B7/RS6(?) setups I've read about here? Problem is that, as I've just trumped up the cash for the car, I'd like to keep my spend down for the next couple of months... (wouldn't we all :lol:)
All help much appreciated!
Left:
Right:
RS4 B5, Ebony Black, Miltek & MRC Magic: 450bhp
Virdee Autos
Trader (Expired)
RE: Newb with rear disc query!
Post by Virdee Autos » Sun Aug 17, 2008 3:24 pm
Yes I would also put that down to the car not being used as often, especially from the rust on the disc and around the pads.
Best thing to do, if your on a budget would be to remove the discs, and get them skimmed by a good machine shop
You'll also need to check the pads, as if you've done a fair few miles, then the pads will also be worn unevenly
If the front is anything to go by, I reckon the back of the disc will be even worse, just my 2p's worth.
Virdee Autos ~ 07950-526592
RS4_Schumi
Post by RS4_Schumi » Sun Aug 17, 2008 7:31 pm
Cheers Virdee, yeah I've done about a thousand miles since I got it and there's been an improvement but obviously it's not solved.
I'll have a call around to see what skimming them would cost me - it might not be a whole lot cheaper than getting a full fresh set, especially if I have to do the pads anyway. And I plan to move to one of the better RS6/B7 setups in the future anyway.........
Thanks for the advice though, appreciate it :D.
simple1
Post by simple1 » Sun Aug 17, 2008 8:13 pm
Most of the alternative set ups use standard rear discs and pads which are more than adequate. If I recall correctly, it is only moveit who enhance rear brakes with four caliper upgrade.
Set of reatr pads are about £100 from Audi and far cheaper from Swedish and German or other site sponsors so replace them and discs will clear up with use.
Rs4Fan
Post by Rs4Fan » Sun Aug 17, 2008 9:42 pm
The reason why your disks look the way they do is because you are not using your brakes enough, especially after your car has been sitting for a while. I use my car as a daily commuter and only the occasional track day fully removes the rust rings. No other set up would change any of this - save your money.
'00 S4 (sold)
'01 RS4 (sold)
'93 964RSA
'94 964 Turbo
'08 E63 AMG
'10 Cayenne GTS
Virdee Autos
Trader (Expired)
Post by Virdee Autos » Sun Aug 17, 2008 10:24 pm
If the rust is really bad, which it looks from the pics, then a new set of pads will not get rid of the rust. It will just make the pad wear uneven again, and loss of brake performance, due to not having full contact area.
boxerdogted
Post by boxerdogted » Mon Aug 18, 2008 7:03 am
As Virdee say's get the discs skimmed and fit new pads, the only thing to check before you pay to have them skimmed is that they are not below minimum thickness, if that is the case it's fit new.
2001 RS4 Misano Red
Users browsing this forum: No registered users and 138 guests
