Airbox Mod
Airbox Mod
Hi guys.
Tomorrow evening i'm going to modify my std airbox as seen in multiple topics on Audizine & Audiworld.
They say to cut a hole in the bottom of the box (approx 10cm diameter), and then re-install it.
My thought is:
- If i cut a hole in the bottom of the box, the air will have TWO different flow directions: One coming from the front of the car (from the std air-duct), and one coming from the hole i made.
Will it be a problem?
I mean, i can't really imagine how much air a 2,7 litres supercharged engine sucks....but i'd suppose it's a huge quantity, and in my opinion two air flow directions would create a big turbolence inside the airbox.
What do you think about it?
Thanks,
Andrea
My thought is:
Thanks,
Andrea
Rs4 b5 06/2001
custom remap - KW V3 - Hotchkis Sways - ASP DTS with poly mount - 034 Street Mounts + Snub with bracket - Apikol rear diff mount and bushes - Gutted precats - DUH Fmic kit - 360x32 floating discs+brembo 6-pot at the front - 710Ns - OEM 18 Hard wheels - JHM shifter/linkage/spring etc - Podi.ca Boost Gauge - Powerflex Bushes - Afterrun mod -
- quattrokid1
- Top Gear
RE: Airbox Mod
but a mate of mine has done it as well, makes quite a difference apparently.
Misano red B5 RS4 710 D/V's SERVICED BY EL GRIZZMO:).... Wife's !!
Tornado red WR quattro
UrS4 saloon auto:) resurected by Unit20
Audi S3 8L Imola yellow
Audi B6 S4 Cabrio SOLD
Audi 100 2.2E SOLD
Audi 80 cabrio 2.6 V6 (SOLD)
Audi 90 quattro SOLD
Audi 100 2.2E SOLD
RE: Airbox Mod
Thanks for your prompt reply.
Ps. sorry for my english
Rs4 b5 06/2001
RE: Airbox Mod
Just done mine, although found that the front triangle had already been cut out, decided to drill various holes in the box that kind of sit above the wing, to be honest not entirely sure if there is any difference or even if it has lost power.
Evo VIII long gone
B5 S4 Avant long gone
Astra CDTI estate with 2 blown gearboxes long gone
BMW M Sport 320d Business Edition tourer the chariot of choice (with DMF about to die) gone
B8 S4 Avant is now the chariot of choice
RE: Airbox Mod
anyone got a pic of where the cut out should be? I'm all for cheap little mods that raise a smile.
RE: Airbox Mod
I'd question what performance improvements cutting the airbox will give you - apart from the throatier intake noise of course. There is a vacuum hose going to the bottom of the airbox - I presume this is for the carbon canister / petrol tank breather but can anyone confirm it's purpose?
It's that age old debate over using Cone filters, CAI (Cold Air Intakes) and the factory setup - unless proven otherwise on the rolling road with suitable cooling if it ain't broke don't fix it....
2012 Audi RS3 in Daytona Grey
2003 VW Golf IV R32 Turbo Deep Blue Pearl - "THE PROJECT"
1993 VW Golf Mk1 GTi Rivage Blue
1968 Karmann Ghia
1968 Karmann Ghia
RE: Airbox Mod
This mod is for S4 airboxes, the RS4 airbox already draws in additional air from a secondary pipe, so I would question the value of doing it on your RS4 airbox.
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
To be honest just remove it and drill a load of holes in the base of it, you'll see where the air feed is from the front wing, so in that area really.
Evo VIII long gone
Look in my gallery - photo of the Sportec airbox for the S4 - tells you all you need to know.Nige_RS4
Are there details of this mod for S4's on the site?
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
- blackb1ade
- 2nd Gear
S'cuse my complete ignorance of such things but.....I thought that forced induction (turbocharged) airboxes had to be completely airtight, in order to be able to create and maintain a certain airflow pressure [to literally RAM as much air in using the turbo's to create a higher pressure in the box, therefore a higher volume of air into the chambers]?
Surely perforating the airbox compromises this??
Avus B5 RS4 with St.3 MTM
- quattrokid1
- Top Gear
doesnt spray from the wheelarch get into the airbox doing this mod?
Audi 100 2.2E SOLD
Audi 100 2.2E SOLD
no, not at all, had it on my S4 for 3+ years. Supposedly adds 5 g/s on an S4.doesnt spray from the wheelarch get into the airbox doing this mod?
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
Id have t agree!! this is wot i think, yeah it may sound better on the induction note as you have a hole in your air boxblackb1ade wrote:S'cuse my complete ignorance of such things but.....I thought that forced induction (turbocharged) airboxes had to be completely airtight,
Soupie69uk
Users browsing this forum: No registered users and 74 guests
