REALLY heavy clutch pedal mechanism
- blackb1ade
- 2nd Gear
I've been meaning to sort this for quite a while, so just thought I'd ask here first - the clutch on my RS4 has always been bloody heavy (I'm not exactly puny and it makes my knee ache in traffic! Plus it's very topical as I just smacked my knee up again and it's now a bit painful to push the clutch)
Is this typical of all the B5 RS4's? Or is it just mine and could it be remedied by changing/re-furbing the Master/Slave cylinders [or seals]?
Ta
Ta
Avus B5 RS4 with St.3 MTM
- mikeyquattro
- Top Gear
RE: REALLY heavy clutch pedal mechanism
How many miles has clutch done? Mine is fairly heavy too. I had a drive of Contigo's RS4 with a new clutch and his was much lighter. I can only presume they get heavier with wear?
Tomorrow is another day
- blackb1ade
- 2nd Gear
Not sure TBH - would have to delve into the service history to look - but it's now done 69.5k and I've noticed that on a longer run, at points where I boot it on the m/way I've had a little clutch slip, so I'm thinking I'll be shelling out for a new clutch soon - but not sure that'll alleviate any stiffness of operation, thought that was all down to the hydraulics
- tdiquattro
Mine was heavy and then once changed it was much better, some peeps say with the SAC self adjuster as the clutch wears the pivot point for the leverage changes and can make it harder, also the later thrust bearings have a plastic collar to make them quieter and this gets chewed up making the operation harder, plus there is the good old grease on the splines etc.
Bleeding the slave can help allot with gear changes/ operation I have found especially in hot weather.
Nige'
2000 silver S4 Saloon
It does get ligher but I think in general the clutches on these cars are just heavy duty to deal with the torque and as such are hard work. In the following reviews from way back the guy mentions that.
"as with the S4, this is one of the most disappointing parts of the car, with a lifeless feel to the change and a long travel across the gate. According to Audi's technical people, the engine develops so much torque that they couldn't find an automatic gearbox capable of taking it. This is one reason for a slightly heavy clutch which, for the uninitiated, can make the change from 1st gear to 2nd somewhat jerky. You certainly don’t feel like flicking up and down the ‘box for the sake of it."
http://www.autoweb.co.uk/car_revs/rev_u ... 2000-2002)
2001 Avus Silver RS4 B5 60k on clock, MRC Custom Remap, Sunroof, Bluetooth prep
2006 Daytona Grey RS4 B7, RNS-E - SOLD
2006 BMW M6 - GONE
2006 BMW M6 - GONE
- blackb1ade
- 2nd Gear
