- OIL -
- OIL -
Hi Guys.
I've read many infos around here about Oil choices for the b5.
I think this forum needs a Sticky about this.
So here we are:
Which oil do you reccomend guys?
- ROYAL PURPLE??? 5W40 or 10W40???
- MOTUL 300V????
Please post your opinion.
So here we are:
- MOTUL 300V????
Rs4 b5 06/2001
custom remap - KW V3 - Hotchkis Sways - ASP DTS with poly mount - 034 Street Mounts + Snub with bracket - Apikol rear diff mount and bushes - Gutted precats - DUH Fmic kit - 360x32 floating discs+brembo 6-pot at the front - 710Ns - OEM 18 Hard wheels - JHM shifter/linkage/spring etc - Podi.ca Boost Gauge - Powerflex Bushes - Afterrun mod -
RE: - OIL -
Do you have a link or maybe can you suggest me where to buy it from?
I live in Italy and can't find it anywhere!!!
THanks
THanks
Rs4 b5 06/2001
RE: - OIL -
Gearbox OIL?
Rear DIFF OIL?
thanks
Rear DIFF OIL?
thanks
Rs4 b5 06/2001
RE: Re: RE: - OIL -
Big Andy W
I think the Quantum range available from VW/Audi retailers is UK only.
Their oils are made by Castrol I believe, can you get that in Italy?
^^^ Exactly.....
Rs4 b5 06/2001
PPL please help me.
i can't find the Synta Gold here in Italy.
Other possibilities??
PS. i also have to change the diff and transmission oil. Any suggestion?
Rs4 b5 06/2001
As a very new owner of an RS4, I too am looking for recommendations on the correct grade of oil to use.
Audi UK state, along with the owners service booklet that the oil should meet VW 503.01 specification, the dealers are saying to use VW 504 (the new standard), etc.....
I spoke to www.opieoils.co.uk and they recommended for a standard engine to use a Motul 0w-30 to stay within the Audi recommendation or to use Silkolene Pro S 5w-40.
I read alot of posts with people using Quantum Synta Gold 5w-40, but where do you obtain it in the UK. GSF seem to only have the Fuchs Titan Supersyn SL 5w-40 as a direct replacement for the Quantum oil.
What's the consensus on the correct oil grade?
I bought Castrol Edge Sport 10W/60 on Doug's recommendation.
Hi Guys.
I've decided to go Royal Purple 5w40. Found it at 16€/lt here in Italy.
But i need to change also gearbox and rear diff oil.
I'll go with Royal Purple MaxGear 75w90 for the gearbox, but not sure what to use for the rear diff.
Any suggestion??
tHanks
Any suggestion??
tHanks
Rs4 b5 06/2001
