chain tensioner.. But one of the marks dosent fit 100% to the mark, after I have turned the engine. Is this okay, or will it fit when there is oilpressor on the chain tensioner? SORRY but dont know all the correct words to tell you the problem
Do I have a problem...
I have just fitted some 2,8NA head.. I have used my S4 cams, chain and
But let the picture talks
quattronutter
RE: Do I have a problem...
the arrows dont line up 100% it looks about right from the photos
Re: RE: Do I have a problem...
I got 16 chain, somethingquattronutter wrote:the arrows dont line up 100% it looks about right from the photos
Re: RE: Re: RE: Do I have a problem...
Maby thish8cak wrote:so whats the benifit of fitting th 2.8 heads?
RE: Re: RE: Re: RE: Do I have a problem...
if you have 16 rollers (thats the parts that hold the links together) between the marks you are ok.
1999 S4 bi turbo imola yellow,grey pearl wheels,now with KO4's.
2001 A6 avant 2.5 tdi,the work horse
also the arrows should line up with each outer part of the square notch in the cam
Wow. So more power with the 2.8 judging by the hole size?matias wrote:Maby thish8cak wrote:so whats the benifit of fitting th 2.8 heads?2,8 om the left and S4 on the right
Wide Body S4
Why not keep the 2.8 cams?
Darren
Darren
Re: RE: Re: RE: Re: RE: Do I have a problem...
I do have 16 rollers between the marks on the cams.. So it must be okay.imolas4uk wrote:if you have 16 rollers (thats the parts that hold the links together) between the marks you are ok.
Users browsing this forum: No registered users and 225 guests
