Map Sensor!
2.2 I5 20v turbo - 315 bhp
Turbo Joe
Map Sensor!
Post by Turbo Joe » Sun May 25, 2008 8:54 pm
How much for one of these instruments, what is the boost limit measurement and does anyone have the part number to hand? Thanks guys.
SKN remap, K&N Filter, Miltek CatBack Twin Jet-
BHP under Construction!!!!
alastairg
RE: Map Sensor!
Post by alastairg » Wed May 28, 2008 9:55 am
ADU RS2 (94-96), 315HP/410Nm: 300kPa. allows above 1.5bar. PM S2 tuner on the forum and ask his advice or Doug at MRC
S2tuner
Trader (Expired)
RE: Map Sensor!
Post by S2tuner » Wed May 28, 2008 10:41 am
Real Bosch 300kPa MAP sensor is not available anymore and hasn't been for the last 6 years. I sold my last one to a customer 3 weeks ago. From now on, only replicas are available, but they work really well too.
VaudiGR
RE: Map Sensor!
Post by VaudiGR » Wed May 28, 2008 9:16 pm
not even directly from Audi or Bosch you cannot find them?? that is most interesting!
S2tuner
Trader (Expired)
RE: Map Sensor!
Post by S2tuner » Wed May 28, 2008 9:20 pm
Bosch has stopped making them, Audi never got internal MAP sensors for any ECU separately.
saf
RE: Map Sensor!
Post by saf » Thu May 29, 2008 3:24 pm
And where can one obtain such a replica from?
S2tuner
Trader (Expired)
RE: Map Sensor!
Post by S2tuner » Thu May 29, 2008 3:45 pm
www.MRCTuning.com for instance :lol: but I'm wondering why you, Moh, would need one??
Turbo Joe
RE: Map Sensor!
Post by Turbo Joe » Thu May 29, 2008 5:54 pm
Stop making the part? That's a bit militant on Audi's part. I assume then that there is a way around it to execute a boost pressure over the 1.5bar limit if you couldn't get hold of one?
Turbo Joe
RE: Map Sensor!
Post by Turbo Joe » Thu May 29, 2008 6:00 pm
By the way, how much are MRC peddling the RS4/RS6 hybrids for?
S2tuner
Trader (Expired)
RE: Map Sensor!
Post by S2tuner » Thu May 29, 2008 6:21 pm
Hang on, if you have an RS2, you can run up to 2 bar on the stock MAP sensor.
saf
RE: Map Sensor!
Post by saf » Thu May 29, 2008 7:08 pm
Blower has an S4. Was wondering whether to go for an upgraded Map sensor or stick with the normal one.
I thought youd never ask Mihnea. I was wondering whether to leave mine standard or get the uprated special MRC one. Im keeping my car for another year so deciding to upgrade it a little, past 1.5 bar. I know I dont need to change the MAP sensor but its an option. If you can tell em any advantages to why I should change it that I dont know about then that will be dandy. And PMing a price for it too.
Thanks for the reply
S2tuner
Trader (Expired)
RE: Map Sensor!
Post by S2tuner » Thu May 29, 2008 7:29 pm
I think you guys missed the fact that this is the RS2 forum????
saf
RE: Map Sensor!
Post by saf » Thu May 29, 2008 7:44 pm
It wa spsoted in the RS2 forum because it wa sassuemd that the upgraded part was an RS2 map sensor so its most likely that RS2 users will have details for it.
S2tuner
Trader (Expired)
RE: Map Sensor!
Post by S2tuner » Thu May 29, 2008 8:10 pm
wrong, the RS2 sensor is mounted INSIDE the ECU, the upgraded one for S4/RS4 (which has nothing to do with all I've said in this thread) is mounted just before the throttle body.
saf
RE: Map Sensor!
Post by saf » Thu May 29, 2008 8:51 pm
Was told this earlier today by someone before I looked at this post. My friend blower alerted me to the fact that he had posted this question this afternoon.
So lets forget the RS2 one. Ermm as were here, you may as well enlighten us with your wise wisdom on why the upgraded replica one would be of advantage to us. Hes planning on running 1.7 bar peak and im planning on running 1.8 peak. How would the ones you sell benefit us and would we need them?
Also just for some info, the one that was being used 6 years ago. Where was that used? In an S4 / RS4?
Thanks again
Users browsing this forum: No registered users and 105 guests
