German on phone dial and answer
Hi guys,
I still haven't had much luck programming the correct language into the bluetooth module with VAGCom.
I have selected module 77 and notice the soft code ends in 22, this states english for display.
Any ideas why the multifunction display in between the revs/speedo shows german?
- PetrolDave
RE: German on phone dial and answer
What is the coding you currently have at address 77?
Currently on 0010722.
- PetrolDave
That's weird because that's the same coding as I have and mine is in English!
Does the DIS show German only when it displays phone information or at other times as well?
Only phone information, Bluetooth connect or disconnect and make or answer a call.
- PetrolDave
I'm out of ideas - 10722 is definitely the correct coding.
One last question - what's the part number of your Bluetooth module , especially the suffix letter? It should be something like 8P0 862 335 x - you can read it easily with VAG-COM.
I'll check that out once the rain stops
Users browsing this forum: No registered users and 170 guests
