FAULTY N75 ?
FAULTY N75 ?
Hi guys. Have a bit of an intermittent lack of power/ boost problem around 3000rpm. fault code 17965 p1557 (over boosting) found in memory. Replaced both noisy DV s today an its still the same. Would a faulty N75 cause this problem as well? Thanks in advance.
RE: FAULTY N75 ?
Yeah - positive boost was what I was getting. Car would go into limp.
RE: FAULTY N75 ?
Yep , i change lots .
Unit 20
0151 3366888
0151 3366888
RE: FAULTY N75 ?
I would say leak first - then if no leaks n75
http://www.MRCtuning.com
VenomAuzS4
RE: FAULTY N75 ?
I've had problems with my boost recently... Sometimes the gauge shows I'm getting the full bar other times it refuses to go over 0.4 bar and there's a noticeable lack of power. Yet when it cools a little the boost comes back!
Is this an N75 problem or somethin more sinister?
