Do rear RS4 B7 brakes fit on to the B5 S4?
B7 Brakes
- andrewneaves
- 1st Gear
Yes they do fit. I have them on my (facelift) S4
See Brooner's write up on fitting front and rear B7 setup:-
http://www.rs246.com/index.php?name=PNp ... ic&t=53686
You need : -
RS4 (B7) rear calipers
RS4 (B7) caliper mounts
RS4 (B7) rear pads
RS4 (B7) brake lines
RS4 (B7) mounting bolts
The suspension legs also need to be drilled because the mounting bolts are larger tho' positioned the same.
It's a really worthwhile mod. If you have RS4 or RS6 setup at the front having the rear's uprated dramatically improves stablility under braking.
You need : -
RS4 (B7) rear pads
