Any Milteked RSs in London?
Trying to determine which route to take in terms of exhaust systems, having heard R33V-Spec's Supersprint was quite suprised as to how it sounded, not to loud on idle, nice hum/rumble when throttled, other than this particular RS4 I think majority have taken the Miltek route.
I was hoping to have a listen to a Milteked RS before i decide, so if anyone is around the london area I would really appreciate 10-15 minutes of their time.
many thanks
nils
many thanks
nils
RE: Any Milteked RSs in London?
does the supersprint have the dreaded resonance between 2000-3000rpm as the milltek does?
Rob
Rob
- rsmonkey918
- 2nd Gear
Where are you N11LS? I've got the full Milltek according to Doug at MRC- but also have the 200cell cats which has performance ramifications....
Sounds the bizz tho
Sounds the bizz tho
Steve
2000 X RS4 B5 Avus short shift, MTM/full Milltek to 460bhp, 19" Audi split rims/BBS CH's in anthracite, B7 front/rear big brake conversion, H&R ARB's/Bilstein PSS9's/ESP gearbox brace, retrofit RNS-E+Nav, ITG/MRC panel filter
2007 '07 Smart Brabus 101bhp, Bilsteins, Bentley Silverlake
2007 '56 Aprilia RSV Factory for some weekends
2004 '53 Honda Rune NRX1800 for other weekends
Think Virdee (R33V-Spec) will be best to tell you exactly how it sounds between each rev range, normally browses the forum in the evenings.
I'm in North London, would love to hear you setup rsmonkey, when you say full system, is this with dp's, cats etc?
Instagram : n_i_l_s
- Virdee Autos
- Trader (Expired)
No resonance as per the Milltek.
And I've been in a Milltek'd car, so know what its like!
Virdee Autos ~ 07950-526592
- blackb1ade
- 2nd Gear
I have full milltek also - dont take the car into London that often TBH - but I'm J11 M25 in case you need it and you're welcome to sit in for a quick blast/listen
(any bloody excuse to drive it!)
It is a litte rumbly between 2 and 3k....good excuse to go faster though - but it's really not that bad - put it this way, my missus doesn't moan about it, so it cant be that bad
Avus B5 RS4 with St.3 MTM
- blackb1ade
- 2nd Gear
blackb1lade, i may take you up on that if you don't mind, depending on whether anyone else is nearer to me, you have a full system though, so it will obviosly sound different to a Cat back set-up which i'm looking to get...
Quite keen to hear the exhaust note from your RS however
Instagram : n_i_l_s
biggingermuff
Where abouts in North London are you Nils? I'm in Winchmore Hill N21 and I work in Finchley N3. I'm running Milltek resonated cat-back with Milltek no-cat DP's. It's no shrinking violet, but sounds great once you're used to it. I know it's not the set-up you're after, but let me know if you want to check it out.
Mike
Mike
Mike
Q7
Q7
- rsmonkey918
- 2nd Gear
According to Doug its the full dp's/200 cell cats thing yes. Not had any issues with it- quite like a bit of a growl but don't find it particularly intrusive- certainly not at motorway cruise speeds anyway. All fitted before I bought it so it took a look underneath to confirm it all....I'm in North London, would love to hear you setup rsmonkey, when you say full system, is this with dp's, cats etc?
Steve
- blackb1ade
- 2nd Gear
