Have the following code.
dhali
Post by dhali » Thu May 15, 2008 7:19 pm
Wednesday,14,May,2008,17:27:50:23446
VAG-COM Version: Release 704.1
Address 01: Engine
Control Module Part Number:
Component and/or Version:
Software Coding:
Work Shop Code:
1 Fault Found:
17521 - Oxygen (Lambda) Sensor; B1 S1: Internal Resistance too High
P1113 - 35-10 - - - Intermittent
Readiness: N/A.
Have cleared it but keeps coming back. I know its the Lambda sensor (EGT ??). But what side and is it the harder one to get too?
p.s. have milltek 100cell cats fitted.
TIA.
Virdee Autos
Trader (Expired)
RE: Have the following code.
Post by Virdee Autos » Thu May 15, 2008 8:06 pm
Nope thats the easy one.
RHS bank. Air filter side.
Internal resistance will always keep on re-occuring.
Virdee Autos ~ 07950-526592
dhali
Post by dhali » Fri May 16, 2008 11:38 am
nice one virdee.
Virdee Autos
Trader (Expired)
Post by Virdee Autos » Fri May 16, 2008 9:23 pm
BTW the EGT sensor is seperate to the Lambda, just thought i'd mention it after re-reading your above post.
dhali
Post by dhali » Sat May 17, 2008 8:31 pm
Stealers have quoted £122.00 for it. Been browsing on the net and found these people who sell Bosch ones,( i take it is Bosch that is fitted as standard?) and it is (CONSIDERABLEY) cheaper. Worth getting? or shall i stick to the stealers? http://www.lambdasensor.com/main/audi.htm
grizz
Post by grizz » Sat May 17, 2008 9:07 pm
It's the same thing but cheaper .
Unit 20
0151 3366888
dhali
Post by dhali » Sat May 17, 2008 9:20 pm
cheers grizz.
fecking robbing bstrds :x
Virdee Autos
Trader (Expired)
Post by Virdee Autos » Sat May 17, 2008 10:02 pm
It's the same as a Passat.
As long as it's Bosch, its the same!
Sebastian
Post by Sebastian » Tue May 20, 2008 2:30 pm
Side note, we have gotten several reports which indicate that aftermarket sensors don't work properly. Now the original/compatible Bosch (or whomever the supplier is) parts should work fine but stay away from generic stuff... ;)
Sebastian @ Ross-Tech.com
Return to “DTC / VCDS”
Users browsing this forum: No registered users and 15 guests
