Front Mount Intercooler Guys
2.7 V6 30v biturbo - 380 bhp
RSTaSIS4
Post by RSTaSIS4 » Wed May 07, 2008 5:38 am
Hi Pals,
Just wondering if anyone of the FMIC guys are running into issues with higher than normal water temperature.
I am currently running a DUH, Due to the fact that our engine bay is so small and tight, Everything is so packed, after the FMIC is fitted in, the factory Fan no longer fit in. I am fine on Highway, However, when i got stuck in traffic after some pulls, my water temp is higher than other RS4s with side mount intercooler.
Any suggestion to improve my current situation?
tdiquattro
RE: Front Mount Intercooler Guys
Post by tdiquattro » Wed May 07, 2008 6:19 am
You could try an audi factory water rad without the gearbox heat exchanger built in (A6 I think), this gives better circulation of the water, then you have to fit a small oil cooler for the gearbox in one of the sides where the intercooler used to be.
You could try without the oil/water sleeve near the oil filter to separate out the oil and water cooling, not sure how much difference it will make?
I run without the belly pan under the engine, others have tried cutting the existing one, without the guard my temps are much lower.
I never went with the FMIC because of my ambient temps and need for the aircon, I find the side mounts work perfectly well.
Nige'
2000 silver S4 Saloon
andream88
Post by andream88 » Wed May 07, 2008 9:25 am
As you can see here (http://www.duhengineering.com/fmic/gall ... /09/08.jpg), there was also a 16" Electric fan ($200)........do you have it?
Rs4 b5 06/2001
custom remap - KW V3 - Hotchkis Sways - ASP DTS with poly mount - 034 Street Mounts + Snub with bracket - Apikol rear diff mount and bushes - Gutted precats - DUH Fmic kit - 360x32 floating discs+brembo 6-pot at the front - 710Ns - OEM 18 Hard wheels - JHM shifter/linkage/spring etc - Podi.ca Boost Gauge - Powerflex Bushes - Afterrun mod -
RSTaSIS4
Post by RSTaSIS4 » Sat Jun 21, 2008 1:21 am
I already got the Fan, but it's still too Hot..
AdamS4
Post by AdamS4 » Sat Jun 21, 2008 7:43 am
Has anyone tried these on there S4/RS4's ???
http://www.kenlowe.co.uk/
I had a couple on my Escort RS Turbo when i had a FMIC and they worked brilliantly. Very slim too.
jeffw
Post by jeffw » Tue Jun 24, 2008 7:40 pm
Mine gets too hot on track (DUH on a RS4 with 520BHP). I'm getting an auxilary Water rad fitted by MRC next month which should cure the problem. This is a custom rad which fits in the drivers side intercooler pod.
Doug_S2
Trader (Expired)
Post by Doug_S2 » Tue Jun 24, 2008 11:16 pm
even the sidemounted 500+ cars get bigger main radiators by removing the water/gearbox cooler.
http://www.MRCtuning.com
andream88
Re: RE: Front Mount Intercooler Guys
Post by andream88 » Tue Jun 24, 2008 11:40 pm
Doug_S2 wrote:even the sidemounted 500+ cars get bigger main radiators by removing the water/gearbox cooler.
I'm going to remove the front end of the car this week, do you have any istructions on how to do this?
Which rad should i buy for example??
Rs4 b5 06/2001
