I have what sounds like a blown speaker/rattle noise from the rear shelf even at really low volumes.
Iv taken speaker out and it looks fine, no tears anywhere and its all intact. But its definitely the speaker making the rattly noise (still makes the sound when the speaker is held in mid air away from anything to vibrate)
Any ideas?
Bose Rear Shelf Subs
Re: Bose Rear Shelf Subs
Got the same problem my self, N/S/R bose speaker. Had a look and found nothing. Just going to replace it. £100 for a new one.loomx wrote:I have what sounds like a blown speaker/rattle noise from the rear shelf even at really low volumes.
Any ideas?
RE: Re: Bose Rear Shelf Subs
Can you fit other 6.5inch speakers in their place, iv just wired in some VIBE SE-K60s that are in boxes so I dont have to put up with the rattling, and they sound good.
Do I need to get adapters? Will I get any problems running them because they are 4ohms?
Audi S4.
RS4 Y-Pipe, K04ed, 440cc Injectors, Miltek Duel Exhaust, Miltek 100cell Downpipes, Uprated Fuel Pump, AP Racing 6 pots, RS4 rear brakes, FMIC, MRC Remap.
- amriksgill
Yes, this all sounds very familiar
and its very annoying too.
I undertsand that the B(l)OSE spkrs work at 2ohms and that an adapter is needed; also that thier signalling is different - invoking the chassis for a ground - so hooking up speakers direct to the BOSE amp is supposedly a no-no.
I am experiencing this same problem... just hadnt decided what to do about it yet
I wouldnt mind hearing how some of you guys out there with more knowledge on the system would sort this...
to get to the speakers you need to remove the rear seat squab then the rear side bolsters (tab at the bottom of the bolster needs bending up the pull the bolster up and away) you can then lift the parcle shelf up and away from the rear screen, its held by 3 poppers at the front.
from what i can tell it might be the rubber buffer bit at the edge of the cone making the noise... not sure how or why though
I had the same problem there is a quick fix for this
I took some super glue and glued the edge of the cone the sound is caused by the slightly lose cone once the cone is tightly superglued on it will be as good as new I aud advisesuper glueing the other side too while ur at it as mine went a month later soo had to take my car apart again
Users browsing this forum: No registered users and 120 guests
