Re-setting ECU
- andrewlowe
Re-setting ECU
Hi, does any one have an idea of how to re-set the ECU on an RS6, I had to take out the passenger seat as the car had turned into a swimming pool from a flood from the pollen filter. The Air Bag light is on saying the voltage is down according to the manaul I have so I think a connection under the seat is not good but I will need to reset the ECU to get rid of the warning light on the dash. Regards Andrew
RE: Re-setting ECU
Need vagcom or other diag tools. See if anyone can help you close. If not where are you in the world?
- andrewlowe
Re: RE: Re-setting ECU
Thanks for the reply, I am in Bristol, If you have any suggestions of who might be worth dealing with that would be great.Stigter wrote:Need vagcom or other diag tools. See if anyone can help you close. If not where are you in the world?
RE: Re: RE: Re-setting ECU
I would hope anyone with Vag-Com in your area would be happy to do it.
I would but I'm in Cambridge.
jimbo1234567
- 5th Gear
have a look here our kid. http://www.rs246.com/index.php?name=PNp ... ic&t=51359
665 bhp + 586 lbft...
Users browsing this forum: No registered users and 23 guests
