Stalling and won't restart.... immobilizer maybe
This happened twice friday morning and 5 or 6 times friday evening. you are driving and all power goes and you look at revs and they are on zero.
Pull over to side of road and try and restart, it spins over fine but will not fire. I tried locking and unlocking with key out of ignition but this did nothing Go into Vagcom which is in the car from FATS run and plug in and open Imobilizer
it says this
Address 25: Immobilizer Labels: None
Part No: Bitte Adress
Component: e 17 eingeben
No Faults Found
or DTCs not supported by controller
or a communication error occurred
then without clearing codes or anything it turns over and fires straight away and runs fine for a while then same happens all over again.
Eventually it starts and stays running for 10 miles home. I am pretty sure immobilizer light is on while turning over and not firing.
The last 10 mile run was after the car was stopped and locked and unlocked again, would this maybe be resetting something.
Does the imobilizer stop it running or just stop it starting?
Thanks in advance
it says this
No Faults Found
Thanks in advance
RE: Stalling and won
Have you tried switching on/off the cruise control to see if it makes any difference ..?
happy dayz .... party ....
quattronutter
ECU fault maybe
this is happening again and when the lights are on I can't VAGCOM its engine module.
I did get the following log, there is another below when ABS and ESP lights were on and it stopped me looking at engine, the brakes have a fault then.
The car was not started or driven between the 2 logs the only difference is that the first was when it would have run fine and the second are when it was in a state that it wouldn't start or run
Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
Address 01: Engine Labels: 078-907-551-AZA.LBL
Part No: 8D0 907 551 D
Component: 2.7l V6/5VT G 0002
Coding: 05711
Shop #: WSC 00067
3 Faults Found:
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
17765 - Cylinder 1 Ignition Circuit: Short to Ground
P1357 - 35-10 - - - Intermittent
17774 - Cylinder 4 Ignition Circuit: Short to Ground
P1366 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 8D0-907-389.LBL
Part No: 8D0 907 389 E
Component: ABS/ESP allrad D36
Coding: 04395
Shop #: WSC 06435
No fault code found.
********Log from scan when I couldn't communicate with engine******
Coding: 04395
Shop #: WSC 06435
1 Fault Found:
18258 - Powertrain Data Bus: Missing Message from ECU
P1850 - 35-00 - -
Coding: 05711
Shop #: WSC 00067
3 Faults Found:
Coding: 04395
Shop #: WSC 06435
Coding: 04395
Shop #: WSC 06435
1 Fault Found:
P1850 - 35-00 - -
RE: ECU fault maybe
Do you have soldered chip? The connection might be sometimes bad.
RE: ECU fault maybe
Its by ABT, do they solder them?
RE: ECU fault maybe
An update on this at last. Its been a few months but yesterday I gotthe ECU back from ABT and it was as they said corrupted. They are billing me a small amount to just cover p&p and uploading the map they already had saved. I will update you on the figure when it arrives.
By coincidence my local VAG dealer welded the exhaust bracket a few days before this all started so I had a chat with them but they seem to think they weld everyday so it is unlikely, i am unsure as in a rush sometimes thinsg get forgotten
RE: ECU fault maybe
Bet it was the welding
Users browsing this forum: No registered users and 92 guests
