Does anyone know what the safe max RPM would be with solid lifters ...
Engine will be as follows
RS4 Engine with 2.4 heads
Pauter S4 Rods
Wossner 8.1:0 pistons
034 Motorsport uprated spring set with Titanium retainers
Stock RS4 Cams
I see 034 sell Solid Lifters, does anyone know of anywhere else in the UK maybe?
Max RPM with solid lifters
RE: Max RPM with solid lifters
Catcams i think.
satanschild
- 2nd Gear
max rpm ..
this is another tricky question .....
were running solid lifters in satans child, as hutch said .... from cat cams
we have 2 cams to try running, one come's on cam at around 4,500rpm to 8,700 and the other from 6,000 to 10,000rpm ....
the issue being "will the 2.7 hold together" at 10,000rpm....? "ill let you know"
Re: max rpm ..
satanschild wrote: the issue being "will the 2.7 hold together" at 10,000rpm....? "ill let you know"
thats what i told him
