Fitting S4 badge to RS4 grill --- How ?
dr_wimpkins
Post by dr_wimpkins » Mon Mar 17, 2008 2:59 pm
Just fitted an RS4 grill to my puppy, but cant see an easy way of attaching the standard S4 badge to it.
Do I have to glue it?
Doc W
All BLOW and no GO.........
SimonS4MTM
RE: Fitting S4 badge to RS4 grill --- How ?
Post by SimonS4MTM » Mon Mar 17, 2008 3:00 pm
Mine is cable tied from the back
Blue_Thunder
Post by Blue_Thunder » Mon Mar 17, 2008 3:39 pm
There was an AW write-up which involved using bits of meccano.
I'd fitted mine with cable ties as well, but found that it got loose over time. Got bored having to redo it a few times, so now it's debadged!
I'll get around to it one day...
jeffw
Post by jeffw » Mon Mar 17, 2008 4:03 pm
I went lo-tech and used a small woodscrew....worked theough :)
dr_wimpkins
Post by dr_wimpkins » Mon Mar 17, 2008 6:20 pm
Nice 1 lads !
Ads4
Post by Ads4 » Mon Mar 17, 2008 8:02 pm
Presuming you've got ye old badge....
http://www.audiworld.com/tech/ext31.shtml
If you've got the newer one, I can only suggest superglue!
Adam.
MRC B5 S4 Avant.
Matt_H
Post by Matt_H » Mon Mar 17, 2008 11:22 pm
I trimmed the excess plastic off the fixing bits, then used some 'no more nails' exterior stuff - worked a treat 8)
Silver 2000 B5 S4 Avant - SOLD
RS4 Suspension
Miltek Exhaust
H&R Anti Roll Bars
Tanoga Short Shift
RS4 Grille
mikeyquattro
Post by mikeyquattro » Mon Mar 17, 2008 11:39 pm
IIRC I trimmed it down to suit and clipped it on. Bobbler should know, he now owns it!!
Tomorrow is another day
rolskii
Post by rolskii » Tue Mar 18, 2008 12:38 am
mikeyquattro wrote:IIRC I trimmed it down to suit and clipped it on. Bobbler should know, he now owns it!!
I used the clips on mine too .... some way or other ... if in doubt - get the araldite out ..... :shock:
happy dayz .... party ....
Philws4
Post by Philws4 » Tue Mar 18, 2008 10:15 pm
B5 S4
Virdee Autos
Trader (Expired)
Post by Virdee Autos » Tue Mar 18, 2008 10:26 pm
I'm not going to bother reading the AW articles, so pardon me if it's already been mentioned, but heres another way. Used this twice now, and never failed!
Get the badge, and cut off the excess tabs at the back, so that your basically left with 2 lugs either side. Do this whilst checking it will fit the grille/mesh and place the badge were you want it, i.e. making sure it fits everytime.
Then once you've got 2 suitable lugs, place it where you want it on the grille, and heat up the 2 tabs with a heat gun or something appropriate. Get them hot enough, so you can bend them, i.e. flexible. Then once they're like this....bend them against the grille backing, and quickly place it under cold water, or alternatively keep some water and cloth nearby to do this.
Job done!
Virdee Autos ~ 07950-526592
