wires
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
g60bv
wires
Post by g60bv » Sat Mar 08, 2008 3:55 pm
are there any switch live wires in the engine bay which is adequate for the the relay on a water injection set up. doesn't have to be a powerful one. just dont want to hook into an ecu or important one. what about one under the passenger side.?
MRC TUNED 480BHP . -SOLD 1.9TDI AVANT 215HP. HYDBRID TURBO. SMOKING
s4woody
RE: wires
Post by s4woody » Sat Mar 08, 2008 5:37 pm
just open up the ECU box and feed a wire from the fuse board and pass it through the box..safer that way..and it,ll be fuse protected..
GARTH ROAD MOT CENTRE LTD
020 83353032
g60bv
RE: wires
Post by g60bv » Sat Mar 08, 2008 7:03 pm
gotcha
g60bv
Post by g60bv » Sun Apr 13, 2008 8:13 pm
ok
how do you get to the back of the box to get a wire in it.?
quattronutter
Post by quattronutter » Sun Apr 13, 2008 8:15 pm
i wired mine into the washer pump fuse
redrod
Post by redrod » Sun Apr 13, 2008 8:15 pm
I have seen neat little hole drilled in, and then a nice gromet to seal it.
RR
g60bv
Post by g60bv » Sun Apr 13, 2008 8:28 pm
but i cant actually get to the back of the box. woundering if ts worth getting to the back of the radio.?
spen
Post by spen » Sun Apr 13, 2008 8:35 pm
lift the ecu out. then drop your wire down the hole. With a bit of luck you'll find it near the brake pedal. or if not drop a straightened coat hanger down then tape your wire to it from the inside. Then in the engine bay retrieve your coat hanger.
S4 - no longer missing 1 engine. Last seen leaving trailing black lines of gearbox oil.
g60bv
Post by g60bv » Mon Apr 14, 2008 11:31 am
i can get the wire into the car. as you've said . but how do you get to the back of the fuse box. it seems encased in a metal chassie, and a load of trim. with no obvious screws...
bobbler
Post by bobbler » Mon Apr 14, 2008 4:16 pm
Isn't the 75X terminal a switched live which you could use instead?
. S4 Nogaro Blue Avant . ECS IV . RS4 handling bits . 18" Ultraleggera . AWE Boost Gauge . MRC Custom Map . 315 BHP . 482 Nm .
g60bv
Post by g60bv » Mon Apr 14, 2008 5:42 pm
'Bobbler' the 75x terminal. ? whats that. and where is it.?
ta
bobbler
Post by bobbler » Mon Apr 14, 2008 7:26 pm
Have a look at the install instructions for the AWE boost gauge here - http://www.awe-tuning.com/media/pdf/ventgauge.pdf (300kb)
Step 11 shows you it, its where I have my gauge wired here for the lights and it only comes on with the ignition.
Its just in the fuse box area by the drivers side, just drop the lower panel down to get at it.
g60bv
Post by g60bv » Mon Apr 14, 2008 9:06 pm
sweet thank you.
flashyg
Post by flashyg » Mon Apr 14, 2008 10:30 pm
Once you have wired it in, should you drop in an in line fuse and switch in to be safe? Not sure if it will be fused.
g60bv
Post by g60bv » Tue Apr 15, 2008 8:01 pm
ok got the wire in. found a load of other stuff under there. a charging lead to something. see pics.
also looks like a relay is missing. any ideas.?
audi car bit 004.jpg (144.04 KiB) Viewed 1794 times
audi car bit 001.jpg (133.09 KiB) Viewed 1793 times
