Could It Be DRC Again??
W8PMC
Post by W8PMC » Mon Feb 25, 2008 5:39 pm
I'm hoping to hell it's not, but had some very odd spirited moments over the weekend (had not driven the car in anger since she's been serviced & had front shocks replaced).
Without boring you with every detail, a sharp left i've taken many times at the same speed, this time had my rear end scrabbling for grip & 4 wheel drifting around it (quite out of shape). Next taking a fairly gentle right hander at speed, the car started again drifting & pretty much lost traction.
The roads were bone dry & my tyres are the correct psi & plenty of tread.
TBH the back end just never felt as tight as it used to (if that makes sense), as their always appeared too much drive to the rear :shock:
Nothing has changed on the car other than a full service & of course the front shocks replaced along with the relevant cylinders. The dealer & Audi refused to change the opposing shocks, stating it is not a requirement on the RS4.
Anyone got any ideas??
Can't get into a dealers for a couple of weeks as i'm mucho busy, but could do with some pointers as she felt far from grippy the 1st time i've pushed her since leaving the workshop.
Paul
05 Blue DMS E60 M5 (Sold)
14 Grey LCi F10 M5 (Rejected)
ARSEY4
Post by ARSEY4 » Mon Feb 25, 2008 6:12 pm
Could it be the alignment? if they dont realign then they tend to mark and put back.
W8PMC
Post by W8PMC » Mon Feb 25, 2008 6:28 pm
Forgot to say all 4 wheels were fully re-furbed (nice job) & yes the dealer did get the tracking & alignment checked, i however doubt as they only charged me £30ish that it was the top drawer alignment check. I had no issue with traction before the front shocks were replaced, just knocking on re-bound & when investiagted the dealer found both front shocks were leaking.
Paul
Love_iTT
Post by Love_iTT » Mon Feb 25, 2008 6:31 pm
W8PMC wrote:...they only charged me £30ish that it was the top drawer alignment check....
You don't get a full 4 wheel alignment for £30 Paul. well if you do then let me the address. I've seen prices as low as £60 but never £30.
Graham
ChrisRS4
Re: Could It Be DRC Again??
Post by ChrisRS4 » Mon Feb 25, 2008 6:41 pm
W8PMC wrote:Without boring you with every detail, a sharp left i've taken many times at the same speed, this time had my rear end scrabbling for grip & 4 wheel drifting around it (quite out of shape). Next taking a fairly gentle right hander at speed, the car started again drifting & pretty much lost traction.
Sounds like it handles the same as an M3 :D
ARSEY4
Post by ARSEY4 » Tue Feb 26, 2008 9:37 am
W8PMC wrote:Forgot to say all 4 wheels were fully re-furbed (nice job) & yes the dealer did get the tracking & alignment checked, i however doubt as they only charged me £30ish that it was the top drawer alignment check. I had no issue with traction before the front shocks were replaced, just knocking on re-bound & when investiagted the dealer found both front shocks were leaking.
Insist that the 4 wheel alignment is done properly, if you remove suspension components I doubt very much whether they go back in the exact same place even when marking. A full alignment done by a proper set up will cost 100+, Ive sat with a perfectionist who did mine and he took a good 2.5 hours.
W8PMC
Post by W8PMC » Tue Feb 26, 2008 8:32 pm
To clarify, i did not have a 4 wheel alignment done during the warranty work etc. I thought i'd requested one on my list (if required), but i was defo not charged for one, just a regular balance after the wheel re-furb & that of course was not £30.
The car is going in on Friday to be checked & have a full 4 wheel alignment done (thanks for the call Rob), so i'll report back then.
Paul
W8PMC
Post by W8PMC » Fri Feb 29, 2008 4:28 pm
Well the full 4 wheel alignment was done today (thanks Rob) & the nearside rear toe-in was out very slightly, although this was unlikely to be enough to cause the lack of rear wheel traction. Some of the other values were out a touch but were within guidelines.
All values correct now & i'll see how she performs over the next few days.
Paul
hairyaardvark
Post by hairyaardvark » Thu Mar 06, 2008 8:40 am
Keep us posted mate - I'm seeing exactly the same symptoms on my '06 car (only done 15K miles and the current tires are decent) ...... cheers
m5killer
Post by m5killer » Fri Mar 21, 2008 10:53 am
mine does the same and ive only had it for three days now, brand new tyres etc
W8PMC
Post by W8PMC » Fri Mar 21, 2008 4:18 pm
No problems, the car is performing perfectly.
Paul
s4woody
Post by s4woody » Fri Mar 21, 2008 5:15 pm
nice name m5killer..mite put that to the test next time im in london..lets just hope the crew will let you change it to m5killed me... :biggrin3:
GARTH ROAD MOT CENTRE LTD
020 83353032
m5killer
Post by m5killer » Fri Mar 21, 2008 7:52 pm
s4woody wrote:nice name m5killer..mite put that to the test next time im in london..lets just hope the crew will let you change it to m5killed me... :biggrin3:
that wont happen the name m5 killer is because of my alpina B10 BI-turbo 560 bhp and 850nm so m5 m6 current ones can only see my dust :D and my middle finger salute, the salute is just the icing on the cake as they see my dust
s4woody
Post by s4woody » Fri Mar 21, 2008 11:27 pm
alpina B10 BI-turbo
nice.. :thumbs:
020 83353032
m5killer
Post by m5killer » Sat Mar 22, 2008 11:52 am
s4woody wrote:
alpina B10 BI-turbo
nice.. :thumbs:
cheers woody, what part of surrey you in as ive got a bungalow in surrey
Users browsing this forum: Bing [Bot] and 303 guests
