Air/Water Intercoolers for the Rs4
2.7 V6 30v biturbo - 380 bhp
andream88
Post by andream88 » Sun Feb 17, 2008 8:19 pm
Hello.
What do you think about air/water intercoolers?
I've seen that many of you have FMIC ICs etc., but no body uses this particular type of IC.
My idea is to build 2 separate air/water systems, with 2 small front mounted radiators and two small ICs in the same position of the original ones.
Let's talk about this ;)
Bye
derdle
RE: Air/Water Intercoolers for the Rs4
Post by derdle » Sun Feb 17, 2008 9:06 pm
So are you planning to use water in a chargecooler and then run that water to a separate radiator to be cooled by the air?
davs4
Post by davs4 » Sun Feb 17, 2008 9:18 pm
Iv'e got a B7 RS4 oil cooler new and boxed, I thought of using this....
andream88
Re: RE: Air/Water Intercoolers for the Rs4
Post by andream88 » Sun Feb 17, 2008 10:01 pm
derdle wrote:So are you planning to use water in a chargecooler and then run that water to a separate radiator to be cooled by the air?
Exactly.
I want to use a chargecooler.
Let me show you:
by PROTOXIDE
http://www.protoxide.it/intercooler_aria_acqua_tubo.htm
by BONALUME
http://www.bonalume.com/zoom.asp?nome=p ... ntercooler#
Do you think it would be better a system like this one, or a "simple" DUH FMIC??
Bye
andream88
RE: Re: RE: Air/Water Intercoolers for the Rs4
Post by andream88 » Wed Feb 20, 2008 8:53 pm
Rs4 b5 06/2001
custom remap - KW V3 - Hotchkis Sways - ASP DTS with poly mount - 034 Street Mounts + Snub with bracket - Apikol rear diff mount and bushes - Gutted precats - DUH Fmic kit - 360x32 floating discs+brembo 6-pot at the front - 710Ns - OEM 18 Hard wheels - JHM shifter/linkage/spring etc - Podi.ca Boost Gauge - Powerflex Bushes - Afterrun mod -
Philws4
Post by Philws4 » Wed Feb 20, 2008 9:10 pm
Can't open any of those :o
B5 S4
andream88
Post by andream88 » Wed Feb 20, 2008 9:16 pm
Rs4 b5 06/2001
Hutch
Post by Hutch » Wed Feb 20, 2008 9:57 pm
Just had a go on the google machine for pros and cons of charge cooling:
Less lag due to shorter intake tract. Can cool below ambient air temp if tank is filled with ice. But can become inefficient once the water warms up hence the need for a rad.
I'd be interested to see results of a charge cooling system. Not quite sure where you would fit it all in the engine bay especially if you're planning to run 2.
I run a duh FMIC and the results are very good, Low pressure drop and very good cooling.
Siena
Post by Siena » Wed Feb 20, 2008 11:09 pm
I ran a chargecooler in my old type 85 Coupe quattro with RS2-spec motor.
The results were a lot better than when I ran an intercooler, even when I went very big.
Siena
Post by Siena » Wed Feb 20, 2008 11:13 pm
I'm going to run the same set-up in my current car, but rather than use coolant with a seperate rad, as I did on my old car, I'm having the twin chargecoolers a bit different - thicker walls.
Because, I'm going to be running R-134A through them.
andream88
Post by andream88 » Thu Feb 21, 2008 1:19 am
R-134A??? What?
@Hutch
The two radiators in the same position of your DUH FMIC, and the chargecoolers in the same place the SMICS are now!!!
Rs4 b5 06/2001
Siena
Post by Siena » Thu Feb 21, 2008 8:24 am
andream88 wrote:R-134A??? What?
@Hutch
Aircon gas.
andream88
Post by andream88 » Thu Feb 21, 2008 8:35 am
So you are going to use Aircon gas in the chargecoolers WITHOUT the radiators?
Tnx
Rs4 b5 06/2001
Hutch
Post by Hutch » Thu Feb 21, 2008 10:03 am
So the inlet tract will be roughly the same as the std intercooler setup so no benefits decreasing the pressure drop.
The real gains your looking for is reducing IATs lower than a FMIC can. I've never had any experience with a charge cooler so i don't know how effective they can be.
The air con gas sounds interesting. Would this not need a larger air con radiator (it's pretty big already). Would you have it running full wack all the time or say link it to IATs, the higher they get the more the air con pump works?
Siena
Post by Siena » Thu Feb 21, 2008 11:26 am
Correct, Hutch. I'm not running aircon in my car, so the standard condenser will be retained, as well as the compressor solely for the chargecooler. I'l devise some appropriate software to control IAT's, and switch the magnetic clutch on and off as required.
Anream88: Yes, the R-134A set-up won't require any additional radiator, other than the stock S4 condenser.
Users browsing this forum: No registered users and 70 guests
