DIGI TV
GBrownlow
DIGI TV
Post by GBrownlow » Sat Feb 16, 2008 10:35 pm
Is the Audi TV package with the sat nav plus digital or analogue ? The brochure suggests it is analogue the salesperson told me it was digital. We are due to discontinue analogue reception in the South West in 2009 which will be very annoying as I thought I was buying it as digital ! The new M3 I test drove was definitely digi and I can't understand Audi fitting an analogue TV when it only has a year of use left.
Can anyone confirm whether or not it is digi or not and if there is a conversion fix available if not ?
P_G
Post by P_G » Sat Feb 16, 2008 10:57 pm
IIRC they are analogue, but I remember my sales consultant saying that at some point they will all be digi fitted because of the switch over. You can get the digi tuner but it is pricey
rAudiguy
Post by rAudiguy » Sun Feb 17, 2008 12:00 am
Hello mate, mine had the analogue tv tuner but i had a digi unit fitted, it's not that pricey and well worth it. PM me for details.
cheers
Jim
Current car..... hmmmmm????
RS4 B7 Gone
RS6 C5 Gone
M3 E46 smg Gone
S3 Gone
Ozrs4
Post by Ozrs4 » Sun Feb 17, 2008 2:54 am
Hi Jim, was yours a DIY retrofit? Thx.
2007 RS4 B7 - Phantom black saloon
rAudiguy
Post by rAudiguy » Sun Feb 17, 2008 9:25 am
No mate, it was Pro job, works all through the normal nav how you would expect. got it done by the same guy who fitted my tracker and the company had just fitted the 1st one to another RS4 for my dealer. Spot on mate. Good picture even up to 80mph in some areas.
If you want the guys details more than happy to PM them too you.
Jim
RS4 B7 Gone
RS6 C5 Gone
M3 E46 smg Gone
S3 Gone
Adam
Post by Adam » Sun Feb 17, 2008 9:49 pm
To the OP - the RS4 is analogue, the newer Q7, A6 etc are now digi as will all new models.
Jim - please PM details to me too. Craigyb offered me a digi but it was in addition to the analogue and needed a separate remote so not ideal for £600
TDiAvant
Post by TDiAvant » Sun Feb 17, 2008 11:21 pm
There is an Audi digital TV tuner available for Current A3's and B6/B7 A4's, and it's a direct replacement for the Analog module. The problem is your looking at £1100 for the part alone. There are after market units available, which can be controlled via the head unit, but unless your using the Audi TV antenna modules the aftermarket antenna's are very poor.
hbk
Post by hbk » Mon Feb 18, 2008 12:27 am
Hi Jim
You have PM
Rgds
Howard
B7 - RS4 Saloon - Daytona Grey - Black Optics
rAudiguy
Post by rAudiguy » Mon Feb 18, 2008 12:19 pm
So do you..... lol
RS4 B7 Gone
RS6 C5 Gone
M3 E46 smg Gone
S3 Gone
Adam
Post by Adam » Mon Feb 18, 2008 1:56 pm
rAudiguy wrote: Spot on mate. Good picture even up to 80mph in some areas.
How does the picture compare to the analogue one (assume you already had this)?
Was it a straight swap of tuner boxes, and using the existing cabling and aerial?
rAudiguy
Post by rAudiguy » Mon Feb 18, 2008 2:44 pm
It has 2 new Ariel’s that sit at the top of the windscreen, not really a problem. Picture is 100% better as it doesn't go all fuzzy like the analogue system when it losses signal. and of course a much better choice of channels. I'm lucky as there are only 2 spots on my way to work that I lose the picture and that only for a few minutes but generally I listen not watch sky sports news on the way to work every morning.
As far as the box goes there is a tuner hidden under the dash and that's about it. I also paid to have the motion sensor removed so I get a picture while driving. haven't yet been distracted by it either!!
Only down side with mine right now is that is only works when the engine is running although I'm having a new K bus unit fitted that will make it work in the same way that the blue tooth works. i.e. when you turn the key to acc it will come on and when you stop it will only go off once you pull the key out. this is been done next week. so any of you thinking of having this done won’t have a problem as it will a standard fitting from now.
If I can be of anymore help let me know or PM me.
cheers
Jim
RS4 B7 Gone
RS6 C5 Gone
M3 E46 smg Gone
S3 Gone
Adam
Post by Adam » Mon Feb 18, 2008 3:09 pm
useful info
was it £599 ex vat or inc vat
was there an additional charge for TV on the move, if so how much?
ta!
rAudiguy
Post by rAudiguy » Mon Feb 18, 2008 3:50 pm
Off the top of my head £599 inc and I think £100 ish for the TV on the move mate
cheers
Jim.
RS4 B7 Gone
RS6 C5 Gone
M3 E46 smg Gone
S3 Gone
Users browsing this forum: No registered users and 368 guests
