Quick Question About Disconnecting Exhaust Valves
Just double making sure I get it right, basically all I do is remove the black pipes and plug them ? Nothing more ?
RE: Quick Question About Disconnecting Exhaust Valves
Basically, yes
You should also close the open metal tube that's left when you pull the pipes off - either with a substitute closed bit of hose (if you're feeling hi-tec) or a foot of insulating tape (if you're like me) - doesn't need to be air-tight or anything, just a bit of weather proofing...
Couple of cable ties are also handy to keep the pipes from flapping about
2007 Daytona RS4 Avant
use the search function - there is a very good post that includes pics etc within the forum which helped me to sort mine out
- hairyaardvark
Yup me too - found a great thread on here. In the end I did a fairly neat job, blocking the black tubes with a screw and a crimped mini-clamp in each case, that I got from Halfords for about 1.99 .
Absolutely and it's much easier to pull the pipes apart at this junction than pulling the black pipe off the valve part!pippyrips wrote:The better way is to disconnect the pipe from the green connector at the opposite end to the actuator, this leaves absolutly no signs of tampering once put back on.
I found this little gem out the day after i did mine
Users browsing this forum: Google [Bot] and 328 guests
