Billet crank
Billet crank
If you're building a hot RS4 lump, I believe you could choose to get a billet crank made to either S4 or RS4 spec then use either S4 or RS4 customs rods to suit. Is this right ie. an S4 crank will fit an RS4 block as long as you use the S4 custom rods and pistons?
If so, what do you guys reckon is the best crank to go for, S4 or RS4?
Cheers,
Andiroo
Cheers,
Andiroo
WIP :to be advised.....
satanschild
- 2nd Gear
crank
andi ... i done it when i got home
they both have the same main bearings, so yes it fits....
so its just the diference in the price of rods you go for ....
RE: crank
Thanks Jack
So the price difference will be a factor, what else do you think in terms of crank design, RS4 against S4?
And probably the same question re custom RS4 rods over custom S4?
Cheers,
Andiroo
Cheers,
Andiroo
RE: crank
RS4 crank I think is alleged to be %20 stronger according to SSP.
http://www.pauter.com/titanium.htm
Mmmmm titanium rods.....
MY 2000 S4
Ebony Pearl
Stage 3 (MRC 400 (ish))
Apexcone 50w HIDS
Ebony Pearl
Apexcone 50w HIDS
RE: crank
But if both were custom billet which would be the better design?
Mmmmmm, titanium rods....... couldn't agree more mate
Cheers,
Andiroo
Cheers,
Andiroo
RE: crank
I take it the S4 crank has larger journals, so even if both were billet the RS4 design would be a 'tad' lighter? Wonder if the difference in weight is quantifiable?
Both would be knife-edged and balanced (plus anything else you could care to think of that you could do), but the S4 one should be comparably cheaper, but at what performance cost, if any?
Cheers,
Androo
Cheers,
Androo
Re: RE: crank
Never really been on mate, plus I'd rather the RS246 knowledge base came to the rescue if possJonnyX wrote:Might be worth asking this question on AW Andiroo, there are quite a few guys running
fully built bottom ends now.
Cheers,
Andiroo
RE: Re: RE: crank
Aren't the journals on the RS4 larger? if it's billet made to order I doubt either would cost more or less
Mark
Re: RE: Re: RE: crank
I'm not sure mate, I know the RS4 rods have an 'extra shell bit at the bottom' so I assumed the journals were smaller overall.MarkB wrote:Aren't the journals on the RS4 larger? if it's billet made to order I doubt either would cost more or less
The cost issue is that there are companies churning out S4 spec billets so the RS4 one would be slightly more expensive (not sure how much yet) as they aren't common.
Cheers,
Andiroo
satanschild
- 2nd Gear
Re: RE: crank
they would be the same mate...Andiroo wrote:But if both were custom billet which would be the better
Cheers,
Andiroo
the same cost..
s4 would be better as i said then you can rep my rods a bit cheaper....
the rs4 journals are smaller..by a nat's nut's
and there would be no difference in weight as they will both be spec'd to suit the job......
i sent rick the spec's tonight, so should have an mail soon.......
RE: Re: RE: crank
Thanks again mate, top bloke
Cheers,
Andiroo
Cheers,
Andiroo
